Old 09-05-2007, 10:05 PM   #1 (permalink)
alden's Avatar
Member Number: 6550
Trouble Removing Factory Rack
Hey...
I recently acquired the ARB Rack ( from ToraSport - AWESOME Vendor) and decided Today was the day to install. I thought removing the Toyota rack was going to be simple...
Well all the bolts were easy to remove, except ONE.
It just spins in place. Any ideas??
thx
alden is offline
Old 09-05-2007, 10:08 PM   #2 (permalink)
Chatsworth 818 FJ's Avatar
Member Number: 1770
Re: Trouble Removing Factory Rack
alden previously said: View Post
Hey...
I recently aquired the ARB Rack ( from ToraSport - AWESOME Vendor) and decided Today was the day to install. I thought removing the Toyota rack was going to be simple...
thx
I had the same issue , I had a small shim i pryed up on the head of the bold as i twisted the screw, I guess u could use a flat head screwdriver, just put a cloth under it to protect your roof. If that dont work bolt extractors are cheep. Or use a left handed drill bit ever cheeper and easy.
Chatsworth 818 FJ is offline
Old 09-05-2007, 10:22 PM   #3 (permalink)
fjcruzer123's Avatar
Member Number: 9059
Send a message via Yahoo to fjcruzer123
What Chatsworth said, or, it might seem counter-intuitive, but if you apply enough downward pressure to the bolt as your turn it you might be able to keep the bolt receiver from spinning with the bolt. You could also tighten it a bit and see if the receiver seats itself again and then try to loosen the bolt with that pressure idea.
“Can you do Voodoo like I do?”
“Not all who wander are lost…”
http://www.myspace.com/fjcruzer123
http://www.zombiehunters.org/
fjcruzer123 is offline
Old 09-05-2007, 10:33 PM   #4 (permalink)
alden's Avatar
Member Number: 6550
Thanks, I'll give those a try.
alden is offline
Old 09-05-2007, 10:44 PM   #5 (permalink)
Kansas Law Dog's Avatar
Member Number: 931
Penetrating oil! Always soak the threads with a penetrating oil before trying to unscrew bolts that have set in place for await. Then shim or wedge the nut (or fixed threaded piece) before applying force to unscrew.
Kansas Law Dog is offline
Old 09-05-2007, 11:00 PM   #6 (permalink)
Air2air's Avatar
Member Number: 6928
Agree with Chatsworth and KLD but I know it may be too late to help now. Did the bolt strip or did the backing nut come loose on the inside?
Air2air is offline
Old 09-05-2007, 11:08 PM   #7 (permalink)
alden's Avatar
Member Number: 6550
Not sure about the backing nut.
I'm guessing if it has it will mean removing the headliner.
alden is offline
Old 09-05-2007, 11:11 PM   #8 (permalink)
dbbd1's Avatar
Member Number: 1611
Another thought, get a little 2-part epoxy liquid, not the gel. Mix it up and try to get just a wee bit under the crown of the nut, between the roof and the crown of the nut. Let it set up for 24hrs and try it again, with some penetrating oil. You are trying to glue the nut back in place so be careful not to get any epoxy on the threads. A toothpick would work good here, try to get the epoxy to "wick" into place.
dbbd1 is offline
Old 09-05-2007, 11:11 PM   #9 (permalink)
Air2air's Avatar
Member Number: 6928
Alden you might luck out if the ARB does not use that bolt. Slim chance of that I know. Have you tried pulling it up hard while turning, or prying it up with a screwdriver while turning?
Air2air is offline
Old 09-05-2007, 11:16 PM   #10 (permalink)
Matt-erator
Matt07FJ's Avatar
Member Number: 1413
Send a message via AIM to Matt07FJ
there's a metal bracket in the headliner that has 2 nuts in it that the rack mounts on. this is held in place by a small metal clip....if you're not careful - the bracket will come lose and start to spin freely inside....the only way I got mine out was to remove the headliner.....
it was a PITA...but I had 3 clips spinning in different locations....
have fun
'99 4Runner - SR5 Sport - Factory Locked
16" FJ TRD SE Wheels w/ BFG A/Ts, Bilstein Front Coilovers, OME Heavy Rear Coils, Pro-Comp Rear Shocks, Full BudBuilt Skids, All-Pro Sliders, TheToyOutfitters Custom Rear Bumper w/ Swing Tire Carrier, 2 Scepter Gas Cans
07 FJC - Sun Fusion - Sold
My Buildup
TLCA Member #16924
Matt07FJ is offline
