Old 02-26-2008, 10:00 PM   #1 (permalink)
TinCan's Avatar
Member Number: 16596
DIY: FJ OEM Air Dam Light Mounts/Brackets
Tin Can’s Do It Your Self: OEM Air Dam light Brackets
Hello and welcome to yet another do it yourself installment for the FJ Cruiser. Today we will be making OEM air dam light brackets/mounts.
List of tools/miscellaneous items:
• Drill Bits and Drill
• 1/8 Aluminum Flat Bar
• Stainless Steel Hardware (Optional)
• Punch
• Marker
• Ruler
• Hacksaw
• Double Sided File
This DIY is very wordy on purpose, so that there is no question of what to do. I’m going to make the basic assumption that one knows how to use power tools. This DIY is written making only one side, the sides are the same just repeat the steps to make another. Note: These tools can also be used to do a jail break…lol!
Step 1: Cutting the Aluminum Flat Bar (Top)
Locate the 1/8 thick flat bar (Picture 1) measure out a 2” line, using the hacksaw cut along the line. Now, take that 2” top plate and file off the rough edges (Picture 2). Then, test fit the top plate on the air dam (Pictures 3a, 3b, 3c & 3d). There should be very minimal movement, move to step 2.
Step 2: Cutting the Aluminum Flat Bar (Bottom)
Locate the 1/8 thick flat bar, measure out 2.5”- 2.75” (I used 3” it was a little too long) using the hacksaw cut along the line. Now, take that 2.5”- 2.75” bottom plate and file off the rough edges. Then, test fit the bottom plate on the air dam (Pictures 4a & 4b). Move to step 3.
Step 3: Marking the Bottom Plate
Locate the bottom plate; test fit the bottom plate to the air dam. Next, using the marker, trace the ring of the air dam from the top, on to the bottom plate (Picture 5a & 5b). Move to step 4.
Step 4: Marking/Drilling the Top Plate
Locate the top plate; using the ruler measure out the center point of the top plate mark with marker. Now, use the punch on that center mark. Then, drill a pilot hole on the center mark; continue to step up to the desired diameter (Picture 6). Move to step 5.
Step 5: Marking/Drilling the Bottom Plate
Locate the bottom plate; using the top plate as a template trace the center hole on to the bottom plate with a marker (Picture 7). Now, use the punch on that “center” mark of the bottom plate. Then, drill a pilot hole on the “center” mark of the bottom plate; continue to step up to the desired diameter (Picture 8). Using both the top plate and the bottom plate, test fit the two (2) plates on the air dam (Picture 9). Move to step 5.
Step 5: Mounting Hardware
Locate the hardware you are planning on using, I used stainless (Picture 10), I don’t like rust. Test fit all the bolts and nuts, they should fit perfectly straight down, if they do not you may have drilled a little off center (Pictures 11a, 11b). Finish, mounting lights and hardware (Pictures 12a & 12b). To do the other side, repeat the steps. Thanks and enjoy, PM me if you get stuck!
diy-fj-oem-air-dam-light-mounts-brackets-img_3644.jpg  diy-fj-oem-air-dam-light-mounts-brackets-img_3611.jpg  diy-fj-oem-air-dam-light-mounts-brackets-img_3612.jpg  diy-fj-oem-air-dam-light-mounts-brackets-img_3613.jpg  diy-fj-oem-air-dam-light-mounts-brackets-img_3614.jpg
TinCan is offline
Old 02-26-2008, 10:02 PM   #2 (permalink)
TinCan's Avatar
Re: DIY: FJ OEM Air Dam Light Mounts/Brackets
Pics: 3c, 3d, 4a 4b and 5a
diy-fj-oem-air-dam-light-mounts-brackets-img_3616.jpg  diy-fj-oem-air-dam-light-mounts-brackets-img_3617.jpg  diy-fj-oem-air-dam-light-mounts-brackets-img_3621.jpg  diy-fj-oem-air-dam-light-mounts-brackets-img_3622.jpg  diy-fj-oem-air-dam-light-mounts-brackets-img_3625.jpg
TinCan is offline
Old 02-26-2008, 10:04 PM   #3 (permalink)
TinCan's Avatar
5b, 6, 7, 8, and 9
diy-fj-oem-air-dam-light-mounts-brackets-img_3628.jpg  diy-fj-oem-air-dam-light-mounts-brackets-img_3627.jpg  diy-fj-oem-air-dam-light-mounts-brackets-img_3629.jpg  diy-fj-oem-air-dam-light-mounts-brackets-img_3630.jpg  diy-fj-oem-air-dam-light-mounts-brackets-img_3631.jpg
TinCan is offline
Old 02-26-2008, 10:05 PM   #4 (permalink)
TinCan's Avatar
10, 11a, 11b, 12a, and 12b
diy-fj-oem-air-dam-light-mounts-brackets-img_3626.jpg  diy-fj-oem-air-dam-light-mounts-brackets-img_3634.jpg  diy-fj-oem-air-dam-light-mounts-brackets-img_3635.jpg  diy-fj-oem-air-dam-light-mounts-brackets-img_3640.jpg  diy-fj-oem-air-dam-light-mounts-brackets-img_3643.jpg
TinCan is offline
Old 02-26-2008, 10:08 PM   #5 (permalink)
TinCan's Avatar
Two Extra pics
diy-fj-oem-air-dam-light-mounts-brackets-img_3637.jpg  diy-fj-oem-air-dam-light-mounts-brackets-img_3638.jpg
TinCan is offline
Old 02-26-2008, 10:10 PM   #6 (permalink)
Custom User Title
DominicG's Avatar
Member Number: 1647
they need to add DIY Master underneath your name... lol
DominicG is online now
Old 02-26-2008, 10:11 PM   #7 (permalink)
SwiCago's Avatar
Member Number: 15488
Nice write up TinCan, but can you put the attached images into the text, like I did on my DIY fog indicator.
After you upload your attachments, preview your post and then you can click the thumb nails to get the full size image URL, with that you can post it directly in the correct step of your post.
Cheers
AL
SwiCago is offline
Old 02-26-2008, 10:21 PM   #8 (permalink)
TinCan's Avatar
DominicG previously said: View Post
lol ask Steve
SwiCago previously said: View Post
I don't know how to post the pics using the photo bucket, I've had people email me how but I get lost. I'll get p2p help and fix all the DIY's. I do label the pics to match the write up. Thanks.
TinCan is offline
Old 02-26-2008, 10:29 PM   #9 (permalink)
SwiCago's Avatar
TinCan previously said: View Post
You don't need photo bucket...What I do is first write the post and add the attachments like you did ... and Then from the Advanced GUI, I do preview.
Now I see my post with the little thumbnail attachments(like you have now).
Then I click on the thumb and it pops up a window with the image, I copy this URL and edit the post and add the IMG tags. That simple...just look at my DIY fog indicator to see what I mean.
EDIT: you can also get the full URL from the manage attachment area under your text edit box.
Cheers
AL
SwiCago is offline
Old 02-26-2008, 10:31 PM   #10 (permalink)
TinCan's Avatar
I'm going to try but no promises lol
TinCan is offline
