Old 03-02-2008, 03:27 AM   #11 (permalink)
SafetyDave's Avatar
Member Number: 13956
Re: Coleman Rack is on!
It is very low profile on the OEM Rack....I'll measure it tomorrow and let ya know how low it is.
This is how I got it on:
I placed some towels down to protect the roof. I removed the OEM top bar rail and moved the lower front rail one behind the rear rail. I then just placed the rack right on the roof and started moving it back. I had the girlfriend push from the front and I was on the roof pulliing it into place. The Coleman rack did "grind" (for a lack of a better term) against the OEM rack. I'll probably Rust spray the OEM rack where the scratchs are. The Spray is almost an exact match for the OEM black color of the rack.
I did notice that I had to even it out as it slid back. The Coleman didn't want to sit exactly even (I was being picky) until I slid the rack into the OEM lower rail which evened it perfectly. I assume that Toyota places all the OEM rails in the same spot from the factory, if your looking to have yours fit like mine.
If I was to do it over again, I might have tried using black tape on the inside rails of the OEM rack for protection. Also It may have slid in a bit smoother with some car washing soap to reduce the friction. If I had moved the second lower OEM rail, the rack may have slid a bit farther back, but I liked where I have it now as it still give room for gas cans on the OEM lower rails.
Only other issue is that the Coleman is so close to the roof, that if I load the Coleman up, it may rub on the roof. I plan on getting those clear little rubber sticky protectors and placing thom on the under side of the Coleman when I pack stuff on top.
I'll throw some more pics up too if you let me know what ya want to see.
The Tick!
"No one sends the Tick anywhere. Fate is my only master. Destiny signs my checks!"-Tick
Click the "The Tick!" above for my build up and to follow the Adventures of The Tick!
SafetyDave is offline
Old 03-02-2008, 04:49 AM   #12 (permalink)
chichid65's Avatar
Member Number: 15447
Looks great Dave!
"A Year Of Change"
2008 FJ-VooDoo blue/4x4/AT/GPS/K&N Air Filter/Revos/Up Pkg.2/VIP RS3200 Plus Security System/OEM Roof Rack/OEM Rock Rails/Tow Package/All Weather Floor Mats & Rear cargo Mat//Recovery strap.
chichid65 is offline
Old 03-03-2008, 11:50 AM   #13 (permalink)
Member Number: 16748
So you COULD have mounted it further forward if you'd wanted to? Interesting idea on the mounting brackets - wish I'd seen this before I ordered $50 in additional brackets. Hrm - maybe I can re-sell them or use them for something else...
ImagoX is offline
Old 03-03-2008, 11:54 AM   #14 (permalink)
oscarr's Avatar
Member Number: 7997
very nice...
ARB Bumper*OME Heavies*3" Skyjacker rear*Stock Steelies*Nittos Terras 295/70/17*Gobi Ladder*Cobra CB*AP Rock Sliders*Black Bezel*Real Wheels Light Bar*K&N Filter*Choped Body Mounts*Parrot Blue Tooth*Eliminated rear Sway Bar.
oscarr is offline
Old 03-03-2008, 12:06 PM   #15 (permalink)
Bayou MOD
neworleansparrothead's Avatar
Member Number: 14078
Looks GREAT!!!!
Kim
Kim GO GameCOX!!! That is the original USC, BTW!!!
Pura Vida!!! Costa Rican for"Pure Life" live every minute of it!
The Cherry Garcia!!! '07 BC 4x2!!! Came home on August 10, 2006! Modded, trust me!! TLCA Member 18935
"New Orleans is the cradle of eccentrics. New Orleans is a gumbo, a melting pot of food, mood, mud and blood, where the Caribbean begins or ends, depending on your point of view." "Breathe in Breathe out, move on!!! Jimmy Buffet
neworleansparrothead is offline
Old 03-14-2008, 03:46 PM   #16 (permalink)
SafetyDave's Avatar
Yes you can mount it closer to the front if you like. My rack sits about 2 inches from the FJ rack.
The Tick!
Old 03-14-2008, 04:07 PM   #17 (permalink)
MIKESCRUISER's Avatar
Member Number: 16266
Looks Great, Nice Install
ME HID headlights - AP front & rears - sliders - skids -LCA - ARB snorkel - ARB roofrack - Ipf 868 - Trd CAI - Hornblaster train horns - Viair 400cc - Bandi mount - Midland cb - Nuvi 650 - ICON fronts - OME 896 rears - TC UCA - M/T classic bead locks - BFG km2 285/70/17 - Fourtreks hi-lift - axe/shovel mount - jerrycan on spare - PIAA 1500 flood lights - PIAA 580 bumper lights - Trucklite rocklights - - Warn M8000 - CL awning - Viking winch line.
MIKESCRUISER is offline
Old 03-14-2008, 04:43 PM   #18 (permalink)
tyree326's Avatar
Member Number: 11216
Very nice, good job! I will be planning the same setup down the road and this definitely helps.
-'07 Black Cherry - UP #2 - Convenience Package - 4x4 - A/T - Locker - A-TRAC - OEM Roof Racks - Rubber Floor Mats - Recovery Strap - Build Date: 02/07.
tyree326 is offline
Old 03-14-2008, 05:26 PM   #19 (permalink)
FJandFU's Avatar
Member Number: 18195
Couldn't find a Japanese made shovel to go with your FJ? Name:  bicycle.gif
J/K.....Looks good. May want to think about getting some rubber tubing like washer fluid tube or vacuum line and slide it over the u-bolts. Kinda like putting a little wet-suit on your u-bolts. That will stop the wear and chaffing that's gonna happen when metal and metal vibrate together. It'll stop them squeeks from happening too. It doesn't make noise now but after a twist and turn on the trail or the speed bump at the market and you'll hear something.
Would Someome Please Hand Me That Piano...
FJandFU is offline
Old 03-14-2008, 06:23 PM   #20 (permalink)
SafetyDave's Avatar
I'll probably go the rubber tubing route... right now they are wapped in black eletrical tape... I'm looking at quick fists for a better solution.
I couldn't find a blue japanese (or US) shovel.... lol
The Tick!
