Old 03-04-2008, 07:48 AM   #1 (permalink)
Member Number: 15292
Send a message via AIM to ISurfer88
trim panels rattle
when i turn my base up the interior trim panels rattle and drive me craaaaaaazzzy! I woudl like to know if these trim panels just pop off and of so what is the best way to do it. I have the basic black plastic trim panels (not the painted ones to match the color of the fj). I just dont want to try and pop something off to add some sound dampening in there just to find out there not ment to pop and accidently break them off.
07 Sun Fuzion FJ 4x4
TRD Rims TRD CAI
Magnaflow Exhaust Pioneer Avic D3
20% Front Window Tint Oznium Dome Lights
OME 886/895 Lift Kit ScubaDriver
XM Radio Cobra CB Radio
285/75/16 BFG AT's
VSC On/Off Switch Atrack/Rear Locker Hack
Future: Rock Rails, Front Bumper? Roof Rack and Light Bar?
ISurfer88 is online now
Old 03-04-2008, 01:02 PM   #2 (permalink)
Banned
Member Number: 16973
Re: trim panels rattle
Dynamat the panels and the metal behind them. They are held in by push pins and a few screws.
SteamFire is offline
Old 03-04-2008, 01:11 PM   #3 (permalink)
MelloFJYellow's Avatar
Member Number: 1046
ISurfer88 previously said: View Post
Hey, I live in Ormond Beach, as well, and my FJ is a 4X4 Sun Fusion, too!
Sun Fusion 4X4 AT CQ GY DL FE XY PW CA TC QS
Mods to date: New and Improved Tire cover, with the FJ, tire tracks, and the word "Cruiser" free-hand painted by my wonderful wife
A-Trac,Dual horn,Goodyear Fortera Silent Armor's w/MB Razor wheels
Florida "Shark" specialty license plate saying "KRUSR"
MelloFJYellow is offline
Old 03-04-2008, 01:13 PM   #4 (permalink)
Member Number: 3024
I dynamatted the door metal, but my panels still vibrate. So, you might want to dynamat the panels themselves and see what that does.
sunfusion07 is offline
Old 03-04-2008, 01:16 PM   #5 (permalink)
Briman42487's Avatar
Member Number: 7204
there are two screws. one behind the door latch lever and the other behind the round door handle. then there is one alien head that is in the front area of the door panel. be gentile and push the center of it in with a blunt phillips screwdriver. (all the screws are phillips heads). then once those three things are out, the only thing that is holding the door in are some clips. if you want to be extra careful you can use a panel popper. below is the set is use. the main one that i use is all the way on the right. it can be had for probably 12-13 bucks. but if you take your time and dont pull hard you can start at the lower edge by the speaker and pull gently. pull straight out with even pressure. from there it will be a piece of cake. once all of them are out, lift slightly and it will come right off. disconnect the cables for the locking mechanism and door handle. then disconnect your door lock and power window harness.
i dynamatted my entire door. the inner layer is mostly done, and the outer layer is completely covered. i run a super nasty mid in the door and a super nasty bas setup and dont get any rattles in the inside.
Briman42487 is offline
Old 03-04-2008, 01:55 PM   #6 (permalink)
rutherk1's Avatar
Member Number: 3982
Send a message via Yahoo to rutherk1
Man. Every time I do one of my vehicles I wish I had some of those poppers. I have gotten pretty creative over the years with coat hangers, dull tin snips, leather punches, and wire strippers I glued at 30 degrees open. I think I even have a dentist pic for taking off screw access tabs.
I have my Tacoma down to the metal. Although my air tools saved a crap load of time with the seats.
Nice.
FJ's = possessive
FJs = plural
rutherk1 is offline
Old 03-04-2008, 01:58 PM   #7 (permalink)
Member Number: 7204
for dissassembling a new car, the best tools i own are those and my panel poppers, miniature awl pick set, bright ass 30 some odd LED with about a 20 hour life on the rechargable battery, and standard size awls.
