brolic previously said:
I plan to install a rally style map light for the passenger side. Thinking about an avanti or hella hard wired light.
I get sketchy when it comes to electrical stuff so where can I hard wire this into?
All of the other map light installs I have seen on this forum have been overhead or they are not hard wired.
I have the Hella 19" rally light mounted on the pass side just to the left of the glove box door at the bottom of the dash. It's a basic two-wire hook-up- black wire to ground, brown wire to 12v positive...you can tap it into the fuse box, or any source that will handle about 1/2 amp current draw (the Hella uses a 6w halogen bulb)...
