I finally got around to putting a rear hitch on my rig. The factory hitch fits perfectly with the WARN rear bumper. It was a pain to install though because I had to pull the bumper in order to mount the hitch. If you are planning to get the Warn rear end, install your hitch before you put the bumper on!! Here is a couple pics.
Finally a aftermarket bumper that you can use ur stock hitch.Looks good.I dont know why other bumpers require a different hitch system.Prob just want to make more money.....
ARB Bumper*OME Heavies*3" Skyjacker rear*Stock Steelies*Nittos Terras 295/70/17*Gobi Ladder*Cobra CB*AP Rock Sliders*Black Bezel*Real Wheels Light Bar*K&N Filter*Choped Body Mounts*Parrot Blue Tooth*Eliminated rear Sway Bar.
Keep in mind, if you bought your FJ from South East Toyota (Virginia down to Florida), you probably don't have a "factory" hitch - it's a Reese. And these do not work with the Warn bumper.
Thanks for pointing that out Manhattan. The Hitch in the photo is the little one that just bolts on to the back of the frame. It isn't like the ones that actually span and bolt to the side frame rails. I'm not a huge fan of the Warn front end either. It is nice that you can use larger winches and the powerplant winch with it though. I'm really happy with the warn rear bumper. It is really solid and well made. It really protects the rear end well. My only complaint is that you have to do some cutting to the plastic behind the rear wheels to install the bumper. I would prefer if they had designed it to bolt on with no cutting like many other rear bumpers. I LOVE my FabFours front end!
I'm stoked that Metal-Tech integrated the hitch into the bumper. better clearance and the bumper is bolted on to the frame at like 10 points, much more than most aftermarket hitches.
Good to know for the folks who had the stock hitch already though. Warn is Quality.
__________________ Ligten up, it's the internet.
air previously said:
Quote from: BigDouggieDoug
The Warn rear bumper works with the backup sensors. I have mine in there and they work fine even though I almost never use them. You can actually see them in the picture I posted. The little disks on the inside of each D-ring are the backup sensors. So go ahead and order the Warn!
