Not to be outdone by
Shadow-Warrior (or at least try
) here's a double M-PAC setup showing that what's good for one of the rear door bays, is doubly good for two of them
. If any of you have the lame stock netting / baskets on the rear door, you know how easily stuff falls out the bottom when there's any bouncing. The
Springtail M-PAC set up allows you to use this space to mount a metal rack mesh to which can be attached any number of different types of storage bags. The bags Springtail sells have textile loops with press-studs on the bottom that
allow easy affixing to the mesh. They come in various sizes for various size "cargoes". Installation is fully covered in
this post in the Springtail section of the forum. It's really just a job of popping off the rear door, drilling a few holes and putting a few small bolts in.
Here's a photo of the dual setup and a close-up of one of the mounting bolts:
