Old 05-14-2008, 09:03 AM   #1 (permalink)
Member Number: 10328
wet okole seat cover question
i just installed my wet okole seat covers and ran into a couple minor fitment issues. the hole in my seat cover for the armrest does not line up with the hole in the seatback...not even close. if i stretch it to line it up, it just bunches real badly in front of the hole. i am probably going to cut a new hole to line it up. my main question is regarding the wire run for the airbags in the seatbacks. what did you guys with airbag seats end up doing? did you cut a slit in the flap of the seat cover? thanks!
edit: one more thing...how many holes are there supposed to be for the armrest on the seat back cover? mine has one hole, but it seems like there should be another hole for the medal stud that protrudes from the seat back as well...so, seems like there should be a big hole and a little hole.
2007 TRD SE
+ 2.5" SAW Coilovers
+ Camburg UCAs
+ Toytec Custom rear springs
+ Donahoe Racing rear shocks
FloJo is offline
Old 05-14-2008, 09:41 AM   #2 (permalink)
Bayou MOD
neworleansparrothead's Avatar
Member Number: 14078
Re: wet okole seat cover question
I have the wet o's as well. I only had one hole for the armrest in the side of the cover. It fit perfectly. Before you cut holes in the cover to line it up, I would call Wet O and get one of their folks on the phone. I do believe if you cut them, you may well void your warranty.
I got the fronts first and then got the backseat covers in the last group buy. I had no problems with either set.
Kim
Kim
Breath in, breath out, move on... Jimmy Buffet
The Cherry Garcia!!! '07 Black Cherry 4x2!!! Came home on August 10, 2006! Modded, trust me!! TLCA Member 18935
"New Orleans is the cradle of eccentrics. New Orleans is a gumbo, a melting pot of food, mood, mud and blood, where the Caribbean begins or ends, depending on your point of view." Jimmy Buffet....
neworleansparrothead is offline
Old 05-14-2008, 10:10 AM   #3 (permalink)
AmityFJ's Avatar
Member Number: 6978
Dont go cutting if it doesn't fit right. Call Wet Okole and get ones that work properly. They cost a pretty penny and you shouldn't have to compromise.
I've got them and they fit perfectly. I am sure they will send you out arm rest pieces that work. My dealings with Wet Okole have been that customer service was very good.
TLCA# 17487
AmityFJ is online now
Old 05-14-2008, 10:24 AM   #4 (permalink)
Swingshiftworker's Avatar
Member Number: 11371
This is interesting.
If it is a new cover, I would just make sure I put it on correctly and, if I did, would take measurements and, if they don't spec out, send it back to Okole for a new one.
HOWEVER, when I removed my front Okoles (which I've sold), a NEW hole just outside the big hole for the arm rest was created around the arm rest spindle and I had to snip the fabric between the "new" hole and the factory arm rest hole to release it. Never could figure out how that happened, but didn't spend much time trying to figure it out. The "snip" can be resewn by the new buyer and, after it's reinstalled, you probably won't even notice it tucked in on the inside of the driver's seat.
So, long story short, if you don't want to send the cover back to Okole for correction, cutting and resewing it properly "may" be an alternative solution. Good luck!
Marty
Vote for Obama in 2008!
2007 Titanium Metallic Toyota FJ Cruiser (4x4 SUV)
2006 Mineral Gray Dodge Ram SRT10 Quad Cab
1999 Red Jeep Wrangler TJ Sport (4x4 Rockcrawler)
My Build Diary
Swingshiftworker is offline
Old 05-14-2008, 12:57 PM   #5 (permalink)
thanks guys, i just called wet okole and the tech said that it would not harm if i were to cut the hole bigger...just to use care. he also said to try to slide the seatback cover on with the armrest on, which others on the forum did. it just seemed much easier to take off the armrest, but i guess there is a reason to slide on seat back cover with armrest in place for a reason.
2007 TRD SE
+ Camburg UCAs
FloJo is offline
Old 05-14-2008, 01:11 PM   #6 (permalink)
athenaceleste's Avatar
Member Number: 10921
Send a message via AIM to athenaceleste Send a message via MSN to athenaceleste Send a message via Yahoo to athenaceleste
yeah check into it before you go and cut something. I think that was one of their questions through the custom order process about airbags.... hmmm call 'em
THE BLACK SHEEP SHEPARD... shall you follow?
We're easily amused.................
upgrade #1, xm radio, trd, CAI
powertank with air tools~Fabfour front and rear bumper/bulldog winch~Suspension-OME 3" lift, front 886~ rear 896 (heavies)~system-3 JL 10" subs multi surround speakers~Gobi Rack with 3 sets of PIAA's~35/10.5/r16 swampers SSR's (bodymount chop)~Rasta skid plates~fender flares removed~ She's almost done
http://www.toyotatrailteams.com/?section=2.4.8882
http://rasta4x4usa.com/fjcruiser.aspx
athenaceleste is online now
Old 05-14-2008, 01:38 PM   #7 (permalink)
ballkillerxxx's Avatar
Member Number: 16315
Send a message via Yahoo to ballkillerxxx
always best to check with them first, i got lucky we have a wet okole factory here so i had them install it for me.
08 BLACK DIAMOND, OFFROAD PACKAGE, CQ,
WET OKOLE SEAT COVERS
HEAD UNIT ALPINE IVA-W205. BLACKBIRD PMD-200,
REAR VIEW CAMERA
EVERYTHING ELSE ROCKFORD FOSGATE
AMPS P200-2, P-400, 1500IBD. SPEAKERS
SUB T212D2, CAPACITOR 2.5 FARAD
MORE MODS TO COME IN THE FUTURE RIGHT NOW TOO BUSY SAILING THE SEVEN SEAS WITH THE NAVY!!!!!!!
:rocket
"Damn the torpedoes, Full speed Ahead"Admiral David Glasgow Farragut (1801-1870)
ballkillerxxx is offline
Old 05-14-2008, 01:43 PM   #8 (permalink)
Toledo FJ's Avatar
Member Number: 14676
funny, I was just going to post a question about wo seat covers myself. I've had the front in for a while and love them. My rear set arrived yesterday, but I'm having a problem installing. First of all they don't have any instructions..... seems to be pretty typical of aftermarket stuff. When putting on the seat back covers, you need to push the fabric under the seat back so it can velcro to the back of the seat. The problem is that there is a seatbelt in the way, so I can't pass the fabric under the seatback. Do I need to cut it there so it can slide through?
Toledo FJ is online now
Old 05-14-2008, 05:20 PM   #9 (permalink)
Bayou MOD
Toledo FJ previously said: View Post
I unbolted my seatbelt at the base of the seat on the passenger side. Then, slide the seatbelt through the hole and wallah! It worked perfectly. Just remember to crank down pretty good on the bolts at the seatbelt base when you put them back into place. They are seatbelts, after all, you want to make sure that they are good and tight.
Kim
Kim
Old 05-14-2008, 08:43 PM   #10 (permalink)
Member Number: 13785
Just wondering...did you guys all purchase front and rear seat covers, or just front?
nc_fjizzle is online now
