Old 07-10-2008, 02:50 PM   #41
SouthTexasCruiser's Avatar
Member Number: 17680
Re: FJ Dog barrier / Cargo barrier concept
Can the quick fist be mounted on the other side towards the front?
2008 Desert Camo
My Build:
The Landshark
SouthTexasCruiser is offline
Old 07-10-2008, 03:46 PM   #42
Hindsight's Avatar
Member Number: 14207
redfernsoljah previously said: View Post
Looking good. The question will be in my mind. How much will it rattle and some trim pieces in the rear would look nice. Can you take some more photos like the mounts and from the front? Alot of space is left up top. What about emergency egress? just suggestions ...
There should be no rattling as the mounts are quite solid. I'm not sure what you are suggesting for the trim pieces, we will try to keep the coat hangers and may attempt to match the powder coat to the ceiling (at least grey?)
An emergency exit has weighed heavy on my mind...we actually have made the barrier unescapable from the front...I may have to include a spring-loaded punch to blow out the back window if you are unfortunate enough to get stuck back there. I wish that toyota would have put a handle on the inside of the rear door.
I will post better mount pics with the next prototype...the current ones are all chopped up.
Doc
www.springtailsolutions.com
Specializing in Quality Rear Cargo Storage Solutions for FJ Cruisers and Jeep TJ
Based on Military MOLLE Technology
Check out our Presale on FJ Console and Vent Racks
Current Specials
FJ Rear Door Combos $260.00
FJ Side HD Rack Combos $170.00
NewFJ Center Console Straddle Combo $94.00
Springtail LLC
2602 Carbonado Road
Oskaloosa Iowa 52577
Hindsight is offline
Old 07-10-2008, 03:47 PM   #43
Hindsight's Avatar
SouthTexasCruiser previously said: View Post
Not with this design...it is something that I want to change with the next prototype.
Doc
Current Specials
Springtail LLC
2602 Carbonado Road
Old 07-10-2008, 05:53 PM   #44
redfernsoljah's Avatar
Member Number: 6109
as far as safety how about a small solution for the rear door maybe an emergency pull strap? or similar type of mod to get the door open?
4x4 AT Black Diamond
#56003
CQAT, DLAT, GYAT, TR10, CR10, TU50
Icon Lift, Baja Rack, ARB Bumper, Smitty 8k Winch, Warn Rear Bumper, Lucrum Swingout, TRD Rock Rails, 285/70 Terra Grapplers, CAI, TRD Ehaust, Snorkel, HID Upgrade, Kenwood KNA-510 and HU, Engel 45, Custom Rear Storage Box, Springtail Divider, Springtail Rear Cargo, Kifaru Woobie, Custom Medical Kit, Survival Kit, Mossberg 500, SIG P6
2008 Ducati Hypermotard
Arrow Full Carbon Exhaust
redfernsoljah is offline
Old 07-10-2008, 07:01 PM   #45
Hindsight's Avatar
There is a mod out there to add a button to pop open the rear window, then a person could reach out and open the door.
Doc
Current Specials
Springtail LLC
2602 Carbonado Road
Old 07-10-2008, 07:07 PM   #46
imgone10's Avatar
Member Number: 8695
Send a message via AIM to imgone10
Doc that looks real nice can't wait to see it in person at the summit.
imgone10 is offline
Old 07-10-2008, 09:33 PM   #47
blackseabk's Avatar
Member Number: 7025
Hindsight previously said: View Post
Doc
If I might suggest may be a hinged barrier it folds up and locks where you could undo from the rear seats alone with rather than using solid piece of metal just a cable smilar to tailgate holder attach to the coat hook from one end and using some quick disconnecting latch like seat belt latch that way you will still have the support for the top from moving cargo. Just an idea.
blackseabk is offline
Old 07-11-2008, 07:41 AM   #48
Hindsight's Avatar
The problem with a folding barrier is primarily that there is no room to get out of the way when it folds...we originally thought that having a knurled knob on the upper mounts may work, then you could just manhandle the rack forwards or backwards (unfortunately destroying the mounting points). But the headrests prevent forward movement and there is very little room to pull it backwards...virtually none if you have cargo mounted on the side racks.
Another option would be to redesign the lower mounts so that they were not integral with the base and could be disassembled by hand...then the whole thing could be popped out in a pinch.
Doc
Current Specials
Springtail LLC
2602 Carbonado Road
Old 07-21-2008, 11:30 PM   #49
Member Number: 6109
what are we looking at time frame wise here for a final product? installing a cabinet in the rear for my engel and some starage possibly above it and use a slide on it. As far as cargo the engel severly limits what I can carry so a few things stacked up upon another and bang in the head if I gotta stop fast. Thinking of find some hardigg or pelican that would fit in there well. May not be able to see out the back but will have an easy pack.
#56003
Old 07-22-2008, 06:45 AM   #50
Hindsight's Avatar
We are just getting back from showing the concept at FJ Summit, everyone was very positive and offered some excellent input on the idea. The interest was so high that I am bumping all of our current projects and putting this at the top of the priority list.
We have to make some significant changes so an entirely new prototype will have to be made and then reevaluated. If all goes well this is what you will see.
1) easy mounting without any tools...in and out in 5 minutes
2) mountable on both sides
3) the center bars will have coordinating holes to mount an FJ rear MPAC Rack if so desired
If interest is high enough, I would look to seeing a delivery date of 90-120 days.
BTW: It was great meeting everyone at the Summit and finally putting some faces to the forum names!
Current Specials
Springtail LLC
2602 Carbonado Road
