Old 07-29-2008, 01:38 PM   #61 (permalink)
Hindsight's Avatar
Member Number: 14207
Re: FJ Dog barrier / Cargo barrier concept
smurfj previously said: View Post
Hey I like the idea. If you could make it look similar to the ones on Volvo station wagons and be a removeable piece it would be great. Keep us posted on your updates.
If all goes as planned...removal will require no hand tools and should only take about 5 minutes or less.
The new prototype will test a mounting system utilizing knurled knobs like these below.
Doc
www.springtailsolutions.com
Specializing in Quality Rear Cargo Storage Solutions for FJ Cruisers and Jeep TJ
Based on Military MOLLE Technology
See the new Rear Door STAT Combo for 2010
Click Here
FJ Rear Door Combo (Now with STAT pouches) $250.00
FJ Side HD Rack Combo (Now with STAT Pouch) $179.00
FJ Center Console Straddle Combo $94.00
Now available for the M6
FJ Barrier is Back! $179.00
Click here to get it!
Springtail LLC
2602 Carbonado Road
Oskaloosa Iowa 52577
Hindsight is offline
Old 07-29-2008, 01:48 PM   #62 (permalink)
DominicG's Avatar
Member Number: 1647
Location: OC, SoCal.. But stuck at Eglin AFB, FL.. In the Army.
I like that..
DominicG is offline
Old 07-29-2008, 01:57 PM   #63 (permalink)
1poser's Avatar
Member Number: 12934
Hi doc, good meeting you at Ouray and I'm happy with the rack system thanks again for installing it right there'n then! It sure cleaned it up back there...no real heavy things in the bags, all the heavy stuff I have in the TT schwag bags.
the cage would be a good safety feature in case off the nasty.
keep up the good work!
Victor
1poser is offline
Old 07-29-2008, 07:51 PM   #64 (permalink)
Hindsight's Avatar
Victor,
The Rear rack looks good! Not too bad for getting done in the dark
I'm pretty pumped about the barrier, hopefully these lower mounts prove to be as versatile as I think they will...I should have some drawings in a couple of days.
Doc
Click Here
Springtail LLC
2602 Carbonado Road
Old 08-04-2008, 10:54 PM   #65 (permalink)
Member Number: 16900
This is a very cool product. We have been looking for a similar item for our FJ and our dog. I was wondering if the metal mesh is sharp. I guess I'm concerned that if we stop quickly our dog could get injured on the mesh. That would be a bummer.
Thanks for any info!
mdwkpdx is offline
Old 08-04-2008, 11:17 PM   #66 (permalink)
SkyKing's Avatar
Member Number: 10079
RabidPooch previously said: View Post
Only making this comment because you asked. I know you said it is not something you see as a future possibility.....but THIS dog does not travel comfortably stuffed behind the back seats.
This is my breed of choice. Sometime, somewhere, from someone, I plan to buy a barrier of sorts that will fit behind the driver's seat with the back seats down.
I know you said it would be a weight and shipping issue to make it to fit behind the front seats......but since it butts up to the back of front seat, isn't the general concept very close?
Looks to be about the same size as our Bull Mastiff. He is about 125, and still growing... Way to big to try and force in the very back...
Reggie needed us to make a choice, and we did. Our FJ is now a 2 seater 100% of the time.
For us, we would need a barrier that will fit the front seats. It would be so nice if you could do a front seat barrier for us "Big" dog people.
I must say, yours does look real strong, about the best I have seen.
SkyKing is offline
Old 08-05-2008, 01:30 AM   #67 (permalink)
Hindsight's Avatar
mdwkpdx previously said: View Post
The mesh loses it's sharpness with the powdercoat process. We were careful to pic a style of mesh that would resist cutting little fingers and wet noses. Injury is always possible but will be less likely than if there was no barrier there at all (ie: less distance for your dog to travel before hitting something solid).
The redesign should allow for a flat surface to the cargo area and we have flattened the center angled metal for the surface facing the passenger compartment. I will try to get some pics of the redesign up soon.
Doc
Click Here
Springtail LLC
2602 Carbonado Road
Old 08-05-2008, 09:45 PM   #68 (permalink)
Hindsight's Avatar
New redesigned concept pics
Note the removable lower mounts and flat center bars that will allow mounting of items on both sides. We decided to keep the flat mesh surface on the cargo side due to welding issues and now that the center bars are flat, there is no issue of any sharp surfaces near the head rests on the passenger side.
The price went up a bit (about $15.00) with the addition of the 2 lower removable mounts and special hardware so I anticipate a Forum price of $215.00.
We should have the real item to test in about 3 weeks
REAR VIEW
FRONT VIEW
Doc
Click Here
Springtail LLC
2602 Carbonado Road
Old 08-05-2008, 09:47 PM   #69 (permalink)
DominicG's Avatar
Member Number: 1647
I think i'm gonna want this..
Will we be able to attach MOLLE bags to it?
DominicG is offline
Old 08-05-2008, 09:59 PM   #70 (permalink)
Hindsight's Avatar
The center bars will be set up to take a standard #10 bolt (Quickfist size) and as you can see there are a lot of holes for different configurations. We are planning on cutting coordinating holes in future FJ rear door Racks (to directly bolt up to the barrier) for those who want to hang MOLLE bags. We will just have to see how the new lower mounts work out in real life.
There have been a lot of small changes as well, we had lots of constructive input at Summit.
Doc
Click Here
Springtail LLC
2602 Carbonado Road
