Fjamming previously said:
Looks good Steve. Could you show me how you ran the positive wire? I'm not sure you run it into the plastic panel inside. Did you have it go throught the lower portion of the hitch on the right or did you drill?
I forgot to take a pic before I heaved the spare tire back on.
The positive (+) lead runs down the back of the spare tire to the plastic molding (which is actually two halves that meet in the center). There's a screw that allows the molding to be snapped away from the door at the lower edge.
I tucked the wire behind the exterior molding and ran it along the
bottom edge until it reached the left edge of the door. From there, it followed the molding (that wraps around into the interior) up to the door wiring grommet.
Nope, no drilling required.
