Old 11-02-2008, 10:09 PM   #11 (permalink)
Moderator w/benefits
five-by-five's Avatar
Member Number: 14804
Re: Blacking out side mirrors
Nice pictures, I've always been a visual learner!
05/06 built '07 6MT accessorized with the following:
LT285/70/r17 Nitto Terra Grapplers on stock rims, Extreme Truck Toys 3" spacer lift, Demello front single hoop bumper + skid plate, K&N CAI Intake as reviewed by me here on FJFCs, Trail Gear sliders, Cobra 76 XTR CB + 3' Wilson Silver Load antenna mounted up front, A-TRAC hack and custom trail rash from all over Texas.
five-by-five is online now
Old 12-28-2008, 10:01 PM   #12 (permalink)
Member Number: 24645
you inspired me paint my mirrors this weekend when i have ample time to do the job properly! thx for the great pics and helpful step-by-step, a newbie like me really appreciates it
just wondering, how did you remove the "TOYOTA" from the front grille to paint it red? looks very slick
Murdered08 is offline
Old 12-29-2008, 08:10 AM   #13 (permalink)
MSGTCWT's Avatar
Member Number: 22310
Thanks for the comments. When I did my front Toyota emblem, I removed the bezel and the grill. The emblem has plastic studs that have been melted on the back of the grill to hold on the emblem. So I desided to mask of the grill with tape and used a good set of razor knifes to trim it out. Took me about 30 minutes to trim out. Do a search and you' ll find a few post with the bezel mods. I did a thread on it also. Have fun I hope this helps.
2007 4x4 FJC/ Sun Fusion, AT/A-TRAC /E-Locker Sub/RevTek 3'' lift with top leveling spacers, 33''x12.50x17 Baja MTZ, 17'' Eagle Alloy Rims, Trail-Gear Rock Sliders, Garmin nuvi 680 GPS, Bandi mount, 3'' Firestik, Cobra 75 WXST CB, RiteLites, Life Hammer, All-Pro Sway Bar Collars, Scuba Driver Mod, Hi-Lift 485 Jack, and FJCF badge.
Check out my Build "Hellhound"
http://www.fjcruiserforums.com/forum...hellhound.html
TLCA Member #19475
MSGTCWT is offline
Old 12-29-2008, 08:44 AM   #14 (permalink)
Romag's Avatar
Member Number: 11591
Send a message via ICQ to Romag Send a message via AIM to Romag Send a message via MSN to Romag Send a message via Yahoo to Romag
This is a great post, I hadn't seen a mirror painting post that was as well photo documented as this one, this is my next mod, thanks!
My '07 4x4 FJ Cruiser
Romag is offline
Old 12-29-2008, 08:49 AM   #15 (permalink)
phulcrum's Avatar
Member Number: 24373
awesome write up. i have been wanting to do mine for some time and this will help a lot. thank you!
phulcrum is offline
Old 12-29-2008, 09:22 AM   #16 (permalink)
bigkremey's Avatar
Member Number: 23862
MSGTCWT previously said: View Post
I didn't like the Flat Black look so I went with Satin Black, blends better with the black plastic on the FJ(I think).
I agree. I was going to use the flat black as well, but went with the Satin / Glossy paint. Really does blend better IMO.
bigkremey is offline
Old 01-29-2009, 12:48 PM   #17 (permalink)
idvegas's Avatar
Member Number: 20347
Hey what's up man? i was wondering if it is required to do anything more than just spray the mirrors? i haven't paint any mirrors before so i dont know anything about these things. I'm planning to do my own blackout, but i dont know if i need anything else than just a can of satin black spray?? Any recommendations to keep in mind when i do it?? thanks!
idvegas is offline
Old 01-29-2009, 01:01 PM   #18 (permalink)
You'll more than likely need some sandpaper & blue painters tape.
Old 01-29-2009, 01:05 PM   #19 (permalink)
rockland's Avatar
Member Number: 20180
It shouldn't be too much work if you leave the side mirror casing on, just remove the glass mirror and paper the FJ. I plan on popping a bright PIA in the there anyway.
Check out my build.
The Warlord
rockland is offline
Old 01-29-2009, 01:15 PM   #20 (permalink)
BSea's Avatar
Member Number: 7474
idvegas previously said: View Post
Just make sure you either use a good adhesive, or use paint designed for plastic. I just used krylon fusion for plastic in satin, and so far so good. I used about 4 coats. I didn't use clear because I could only find matt finish. It might be ok, but I wasn't sure.
I also painted over the black part of the mirror just to be sure that the 2 sides looked the same.
BSea is online now
