Hi all! I'm sure this has been posted some where on the forums before but I couldn't find it, so I did mine yesterday and here is a step by step. Hope this will help someone out soon. I didn't like the Flat Black look so I went with Satin Black, blends better with the black plastic on the FJ(I think).
Before.
Remove plastic clip with a screwdriver or something with a point.
Next Remove two screws(one behind door handle and one behind door grab).
Next start at the bottom of the door and pull off the door panel. Then work your way to the top. Push up on the door panel and pull away from door. You will now need to disconnect the two cables that go to the lock and door handle. Then unplug the electric plug that makes your window and door locks function(one on the drivers side and two on the passenger side).
2007 4x4 FJC/ Sun Fusion, AT/A-TRAC /E-Locker Sub/RevTek 3'' lift with top leveling spacers, 33''x12.50x17 Baja MTZ, 17'' Eagle Alloy Rims, Trail-Gear Rock Sliders, Garmin nuvi 680 GPS, Bandi mount, 3'' Firestik, Cobra 75 WXST CB, RiteLites, Life Hammer, All-Pro Sway Bar Collars, Scuba Driver Mod, Hi-Lift 485 Jack, and FJCF badge.
Now you should have the door panel removed. Next remove the four 10mm bolts on the upper black metal plate.
Behind the black metal plate are three 10mm bolts that hold your mirror and the electric plug for your mirror lights. Remove the plug and the three bolts. The mirror has a plastic clip that will hold the mirror in place while you remove the bolts. Next pull some what hard on the mirror and it will come off.
Plastic hook that will hold the mirror.
Now sand and paint then replace.
Hope this helps!
Great write-up and pics. This is why this forum is tops. People helping people. Looks great. I'm thinking on doing the mirrors to. Already blacked out the bezel and back bumper pieces.
__________________ Silly Wabbit Mods: BFG AT's, stone guard,vent visors,window tint,blacked out bezel/rear bumper. Joels grab handles. See Avatar. Demello front winch bumper/center hoop/Acro lights Titan 12k winch,recovery gear Scangauge II
Joel's FJC badge
Gobi Ladder
Custom rock rails
Quick Fist Clamps
Tuffy security console
its like deja vu...me and my friend just repainted my mirrors today to touch them up. I reused the duplicolor trim paint,its a satin paint also.Good job, looks great!!
Thanks everyone! I just finished blacking out my rear bumper today. I might try to post that also, it was very easy. Thanks again for all the nice comments.
It does look good! Personally I used Dragon's method and masked everything off and them painted without any removal. I'm lazy I guess but it turned out good too......
