MPAC rear door storage install!! - Toyota FJ Cruiser Forum
» Auto Insurance
» Featured Product
Register Home Forum Active Topics Photo Gallery Chat Insurance Garage Blogs Search Today's Posts Mark Forums Read
Old 03-25-2009, 10:16 AM   #1 (permalink)
rojo4214's Avatar
Member Number: 25883
MPAC rear door storage/Dynamat install!!
Here are some pics of my MPAC install. This is a great system and I plan on purchasing the side rack soon. I put dynomat on the rear door to sound deaden it a little before placing the panel back on. The hardest part of the install was deciding where to drill the holes. After that, it was pretty easy. My recommendation is to definitely purchase a door panel removal tool at the auto parts store. It only cost $7 but made it so simple to pop the clips out of the door and not break them. Hope everyone likes. Thanks. Shaun
Updated: I dynamated the inside of the rear door. Covered as much metal as and could. Thanks for the input from DoWork. Should sound deaden a lot more. Thanks.
2008 Titanium Silver FJ, Stock roof rack, Grill guard, Auxillary bumper mounted lights, Rhino Predator side steps, MPAC side & rear door storage racks, Custom Valentine 1 Radar Detector Mount, Dynamated rear door, BF Goodrich A/T 265/70/17, Blue Sea 12 Fuse Block, Wolo Bad Boy Horn, Brite Box
rojo4214 is offline
Old 03-25-2009, 10:21 AM   #2 (permalink)
FJ_JK's Avatar
Member Number: 3182
Re: MPAC rear door storage install!!
I have the same set up (and the side rack) and it is a great system. I highly recommend this MOD, Springtail makes a great product.
"Life is tough, it's tougher if you're stupid." John Wayne
FJ_JK is offline
Old 03-25-2009, 10:26 AM   #3 (permalink)
sp8cemtn's Avatar
Member Number: 23191
Nice install. Is the Dynomat making a difference?
08 Black Diamond 4x4
Current Mods
OEM Roof Rack, OEM Brush Guard, Leveling kit, 285/70/T17 Goodyear Wranglers, 4 Lightforce 140's, 2 Hella Black Magic Lamps, SwissArmySUV Fog Lights, Ellis Precision Shift Knobs/Interior Handles/Battery Clamp
Future Mods
BudBuilt Skids, Lucrum Ind winch mount
sp8cemtn is offline
Old 03-25-2009, 10:48 AM   #4 (permalink)
rojo4214's Avatar
FJ_JK previously said: View Post
Thanks for the reply. The side rack is soon to be ordered!
rojo4214 is offline
Old 03-25-2009, 10:50 AM   #5 (permalink)
rojo4214's Avatar
sp8cemtn previously said: View Post
I think it deadens some of the exhaust sound. When I get a chance, I want to do the floor and sides with the dynomat and padding to make it a little quieter. I had some dynomat left over from a previous vehicle. Thanks for the reply
rojo4214 is offline
Old 03-25-2009, 11:19 AM   #6 (permalink)
DoWork's Avatar
Member Number: 18372
did you dynamat over the plastic sheet? I think you did it wrong because it shouldnt look like that. Their are a ton of openings in that outer sheet of body and the way you put the dynamat on will do nothing to stop the noise. The goal is to stop vibrations of the metal which means it needs to be rolled onto the metal tightly
-Mark
08' Black Diamond FJ
View my build
http://www.fjcruiserforums.com/forum...ml#post1145216
DoWork is offline
Old 03-25-2009, 11:27 AM   #7 (permalink)
rojo4214's Avatar
DoWork previously said: View Post
I did not want to remove the plastic cover. At least half the dynomat is on metal. The middle part is just over plastic. I had a couple of extra sheets left over from a previous vehicle so this is why I used it. It has to help some verses not having anything besides plastic.
rojo4214 is offline
Old 03-25-2009, 11:34 AM   #8 (permalink)
DoWork's Avatar
rojo4214 previously said: View Post
It will help a bit but i would recomend peeling the plastic back and putting some on the inner layer of sheet metal, thats where the majority of the vibrations will be coming from. Its pretty easy to peel back if you use a hair dryer and a knife. Then you can cut large sheets and lay them inside which is what I did. Either way the rack looks great!
-Mark
View my build
DoWork is offline
Old 03-25-2009, 11:37 AM   #9 (permalink)
Kylewithrow's Avatar
Member Number: 10219
Send a message via ICQ to Kylewithrow Send a message via Yahoo to Kylewithrow
Great looking setup, very similar to my own. I can't say how useful its been having everything so organized. Doc and Springtail Solutions or great people their awesome to deal with and truly go above and beyond.
The "Infidel" 2007 FJ 4x4 Taitanium Metallic with Linex! All Pro Offroad Front/Rear Bumpers, Rock Rails, Differential Armor, & Shock Skids. OME lift, PIAA 525s, Scuba Modded, MPAC Racked out, BBS wheels, TRD CAI, Hi-Lift Jack Mounted. etc... 1*
Kylewithrow is offline
Old 03-25-2009, 11:39 AM   #10 (permalink)
rojo4214's Avatar
Thanks for the info. I may check it out again. Thanks.
rojo4214 is offline
Powered by vBulletin® Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
