Is a Valve Adjustment really necessary?? - Toyota FJ Cruiser Forum
Maintenance Tech Advertisement
post #1 of 2 (permalink) Old 11-25-2010, 09:24 PM Thread Starter
Quoted: 4 Post(s)
Is a valve adjustment really necessary at some point?? Does the FJ have solid lifters?
Yikes!!! This thing has to last me more than 15 years.
friscocruiser is offline
post #2 of 2 (permalink) Old 11-25-2010, 09:43 PM
1911's Avatar
Quoted: 5 Post(s)
Re: Is a Valve Adjustment really necessary??
It doesn't have lifters, it has overhead cams, the bucket-type shims between the cam lobes and the valve stem. You can check the clearance with a feeler gauge, but to adjust the clearance you have to remove the appropriate cam shaft and replace the bucket shim(s).
Overhead cams with bucket shims will stay in spec for a long long time once they're set up right in the first place, because there is so little slop and essentially no moving parts between the cam and the valve. As a single point of reference, My valve clearances were all well within spec at 90,000 miles when they were checked as a side note to some warranty work. Same with my Sequoia when I replaced the timing belt at about the same mileage. I don't remember when the maintenance schedule says to check the valve clearances, but most people under semi-normal circumstances will not need to have them adjusted for well over 100,000 miles I would guess, and maybe not even then.
N5MUD
4x4ham.com
TLCA # 16550
High Desert Cruisers
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
1911 is offline
Human Verification
