2011 auto transmission fluid change - Page 3 - Toyota FJ Cruiser Forum
Maintenance Tech Advertisement
 6Likes
post #21 of 34 (permalink) Old 07-02-2011, 09:10 PM
Greenbeard's Avatar
Quoted: 1 Post(s)
Question Re: 2011 auto transmission fluid change
1911 previously said: View Post
There isn't one, there is a fluid-level check plug in the bottom of the pan (not far from the drain plug and it looks just like it so be careful). Drive the the truck until fully warm, take out the check plug with the appropriate size Torx bit, and ATF should barely dribble out. If it doesn't, add the proper low-viscosity ATF through the fill plug hole on the passenger side of the transmission until it does.
As I was refilling mine, the fluid wasn't dribbling. It was a regular flow, as if it was the drain plug. It only did this after a certain point. No problems driving at all. I just want to make sure my levels are good. I'm just hesitant to remove the check plug again, in case it comes pouring out. I put back the same amount that I drained. Any suggestions?
Greenbeard is offline
post #22 of 34 (permalink) Old 07-02-2011, 09:28 PM
1911's Avatar
Quoted: 5 Post(s)
Greenbeard previously said: View Post
If you're absolutely certain you put the same amount in that came out, you're OK. You might be checking it a little too hot (the fluid will expand some when hot). But as long as you're using the level-check plug and not the drain plug, it's OK to let it drain until there's just a tiny dribble, again as long as the temperature is not too hot.
N5MUD
4x4ham.com
TLCA # 16550
High Desert Cruisers
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
1911 is offline
post #23 of 34 (permalink) Old 07-02-2011, 09:59 PM
Greenbeard's Avatar
Quoted: 1 Post(s)
I used the Torx/hex plug.
I'd like to double-check. Is there harm in topping it off, just in case?
post #24 of 34 (permalink) Old 07-03-2011, 07:32 AM
1911's Avatar
Quoted: 5 Post(s)
Be careful, both the drain plug and the level-check plug ("overflow plug" in the FSM) are identical Torx-head plugs! The drain plug is at the rear of the tranny pan. The level-check plug is in the middle of the pan, on the passenger side.
There is no harm at all in topping it off; that's what the level-check plug is for, to make sure it isn't over or under-filled. Just be certain that you are using the overflow plug and not the drain plug instead!
N5MUD
4x4ham.com
TLCA # 16550
1911 is offline
post #25 of 34 (permalink) Old 07-03-2011, 08:10 AM
Greenbeard's Avatar
Quoted: 1 Post(s)
I've got a 5AT. There's a regular bolt (drain) and a Torx-head (level-check). Thanks!!!
post #26 of 34 (permalink) Old 07-05-2011, 12:06 AM
RomaBoy's Avatar
Quoted: 68 Post(s)
I'm getting ready to flush/fill my auto trans. What I want to know is why none of you guys never mention changing the trans filter. I read Jayman checked what he called a screen but to me it looks like the trans filter. Toyota calls the unit a baffle but Rockauto calls it a filter
RomaBoy is offline
post #27 of 34 (permalink) Old 07-05-2011, 07:49 AM
jimmiee's Avatar
Quoted: 130 Post(s)
RomaBoy previously said: View Post
If you flip that picture over you will see a screen strainer on the other side. There is no fabric or media type filter like some transmissions have. So there is no need to change this screen.
*All the work on this truck was done by me!*
<NO SNORKEL> _OME Lift -LR UCAs - DeMello FB - 12K# Winch - Hi Lift -Warn RB - TRD muff - Cobra CB / Bandi - A-Trk, Diff Lock, VSC, Chime Hacks - BMC -305-70-16 MTR's & Raceline Renegade's - Wolo - Hi Lift - Tube Grill - Ellis Shift Knbs - Silver Star H4s- Clazzio Leather - Blue Sea Panel - Optima Yellow - Kenwood DNX6980 - Oznium LED- Prodigy BC - SCUBA -Window Tint - Springtail Racks - Tru Cool 4454 - VIAIR Sys -AP Sliders-Ricochet HD Skids - BozTec Diff Skid - ToyTec LCAs & Panhard - Front ARB - 4:56 Gears - Smitty CO2 Cyl - AIRAID CAI - Baja Rack - Lowrance Baja
https://www.facebook.com/jim.eberhart
TCLA Member 4407
jimmiee is offline
post #28 of 34 (permalink) Old 07-05-2011, 08:05 AM
Quoted: 1 Post(s)
The check plug has, "Check" stamped/etched/engraved on it. At least the one on my '08 does.
Gundalay is offline
post #29 of 34 (permalink) Old 07-05-2011, 09:08 AM
Bret's Avatar
Quoted: 0 Post(s)
Same here, 04/07 build date. It makes sense that they use different plugs to avoid a costly mistake.
Bret
member of the 20%
Tropicalreflectionsdetailing.com
tropicalreps.com
2007 Ti, all the dealer goodies + K&N, OME suspension, FlowMaster, Nitto T.G.s 285 70 17
I never submitted the whole system of my opinions to the creed of any party of men whatever in religion, in philosophy, in politics, or in anything else where I was capable of thinking for myself. Such an addiction is the last degradation of a free and moral agent.
-Thomas Jefferson
Bret is offline
post #30 of 34 (permalink) Old 07-05-2011, 11:44 AM
DEWFPO's Avatar
Quoted: 61 Post(s)
jimmiee previously said: View Post
Your efforts are best spent on the ATF and making sure the level is correct.
DEWFPO
Engine Block Heater, '08 Cyclone Pre-Filter, Dual horns, Phillips Osram 70W/65W H4's, RockBlocker and 3M Clear Film, Toyota RearSight Backup Camera, Ultra-Gauge MX 1.3.
"Enjoying the Journey"
DEWFPO is offline
Human Verification
