What power steering fluid - Toyota FJ Cruiser Forum
Maintenance Tech
post #1 of 11 (permalink) Old 08-15-2011, 09:50 PM Thread Starter
Highwaystreets's Avatar
Quoted: 0 Post(s)
So i know the manual says use Dexron ii or iii however i can't find that where i am.... What could i substitute for it? could i use Mobil 1 Synthetic ATF?
2008 Sandstorm | 3 Inch lift | Fab Four Bumper| HID lights | Springtail M-PAC | TT Rock Rails |
In the works |Full Black out | Roof mounted lights |
Highwaystreets is offline
post #2 of 11 (permalink) Old 08-16-2011, 06:45 AM
1911's Avatar
Quoted: 5 Post(s)
Re: What power steering fluid
Highwaystreets previously said: View Post
Yes, and your truck will thank you for it. If you completely flush the power steering and re-fill it with synthetic ATF (like Mobil 1) you will notice a dramatic improvement.
N5MUD
4x4ham.com
TLCA # 16550
High Desert Cruisers
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
1911 is offline
post #3 of 11 (permalink) Old 08-16-2011, 06:57 PM Thread Starter
Quoted: 0 Post(s)
1911 previously said: View Post
thats awesome, thanks. I don't have time to do a full flush in the next 2 days as i'm going away, is it ok to top up with the synthetic and then do the flush when i get back?
post #4 of 11 (permalink) Old 08-16-2011, 07:01 PM
1911's Avatar
Quoted: 5 Post(s)
Yes, Mobil 1 is compatible with all Dexron-type ATF. Top up as much/long as you want, if you're not having any other power steering problems.
N5MUD
4x4ham.com
TLCA # 16550
1911 is offline
post #5 of 11 (permalink) Old 08-16-2011, 07:07 PM Thread Starter
Quoted: 0 Post(s)
solid.... thanks a lot!
post #6 of 11 (permalink) Old 09-23-2011, 12:42 PM
Quoted: 0 Post(s)
What type of "dramatic improvement" will be be noticing? My steering is pretty mellow as it is. Any less feedback and it would be like a Chevy.
2007 Voodoo Blue set up for exploration with the normal stuff and for wheeling 8/73 FJ40, flipped F/R springs, SOA, 60 series front axle, grooved 35 BFG muds, fully locked, 60 series power steering, full cage, 60 series ignition and hydro assist.
www.centralvalleycrawlers.net
slickrock is offline
post #7 of 11 (permalink) Old 09-24-2011, 11:54 AM
Quoted: 3 Post(s)
I personally used Amsoil ATF in the power steering system. I would also consider the Redline power steering fluid
AMSOIL - Synthetic Multi-Vehicle Automatic Transmission Fluid (ATF)
Red Line Synthetic Oil - Power Steering and Misc. - Power Steering Fluid
Flushed it after the first year, was a bit surprised at all the crap that came out. THe drained fluid had a metallic sheen to it
I flushed it again a couple of years ago and the drained fluid did NOT have a metallic sheen to it. Was absolutely clean
Biggest improvement is cold weather operation, the synthetic really helps there. At the upper temp limit, the pump won't groan like some here have reported
Note: if you actually do offroad, do yourself a favor and also put in a power steering cooler. There are threads here on how to do that
If you live in a moderate climate, never offroad, never have temps <-20 F, it is still a good idea to flush the system. You can use any conventional ATF then.
2012 Chevy Impala LS, beige, 3.6 direct injected V6
jayman is offline
post #8 of 11 (permalink) Old 03-27-2014, 07:51 PM
MCcitrus's Avatar
Quoted: 53 Post(s)
I flushed out the factory ATF power steering fluid with AMSOIL (formerly known as AMZOIL) Synthetic PSF (not ATF). Then flushed that out and filled with Synlube PSF. i did this within the first 500 miles of my new FJ. Once it gets discolored i will flush and fill it again.
I recommend keeping up on your power steering maintenance as Toyota isn't known for the best power steering systems. For a real life example, my other half's Lexus 300 had its power steering go at 68,000 miles. And yes, it was properly maintained.
MCcitrus is offline
post #9 of 11 (permalink) Old 03-28-2014, 05:22 AM
RomaBoy's Avatar
Quoted: 70 Post(s)
^^^I've read that using PSF is a no no. BTW, Dexron VI is backwards compatible. Dexron VI backward compatibility | ATF, Differential, Trans, Brakes, P/S | Bob Is The Oil Guy
RomaBoy is offline
post #10 of 11 (permalink) Old 03-29-2014, 08:21 PM
MCcitrus's Avatar
Quoted: 53 Post(s)
So far, so good with the PSF I'm using. They specify it as universal for power steering systems that use either ATF or regular PSF.
I had a Subaru that specified ATF for the power steering and used the Synlube universal PSF for 60,000. Unfortunately, this car was totalled in an accident that wasn't my fault. So, based on that I think I'll be ok with it in the FJ.
MCcitrus is offline
Human Verification
