2012 oil and filter question - Toyota FJ Cruiser Forum
Maintenance Tech
post #1 of 11 (permalink) Old 12-13-2011, 04:30 PM Thread Starter
Quoted: 0 Post(s)
Question 2012 oil and filter question
Has anyone found a way to change oil and filter without removing the skid plate on the 2012 4x4 FJ? I was able to do it on our 1996 v6 4x4 Tacoma and am currently doing it on our 2004 v8 4x4 Tundra. Taking the skid plate off makes the job a lot harder. Has anyone tried cutting an access hole in the plate? Would that and a drain valve work? How do you handle this job?
Thanks
Tom
Jensent is offline
post #2 of 11 (permalink) Old 12-13-2011, 04:52 PM
rumbleph1sh's Avatar
Quoted: 5 Post(s)
Re: 2012 oil and filter question
Jensent previously said: View Post
Thanks
Tom
There's no way to change the filter without dropping the front skid on 2010+ FJ's. It's not really a big deal - just 4 bolts and it's off.
The drain plug already has a small access panel so you don't have to drop the entire skid to drain (another 2 bolts).
All in all, the skids add maybe an extra 5 minutes to each oil change. You will spend much more time trying to find an acceptable solution to this "problem" than you would ever save over the life of your FJ. Just my .02
rumbleph1sh is offline
post #3 of 11 (permalink) Old 12-15-2011, 09:08 PM
AZFJ25's Avatar
Quoted: 3 Post(s)
^^ What he said...
Iceberg 2011 FJC
Build Thread:
The White Sherpa
Amsoil for all Fluids
CactusMotorsLLC
AZFJ25 is offline
post #4 of 11 (permalink) Old 12-16-2011, 03:11 AM
fingas74's Avatar
Quoted: 15 Post(s)
rumbleph1sh previously said: View Post
That's great until the first time you put a little bend in the skid and it fights you every inch of the way to get it back on.
I got a 55 gallon drum of give-a-****, but it echos when I tap on it.
fingas74 is offline
post #5 of 11 (permalink) Old 12-16-2011, 10:17 PM Thread Starter
Quoted: 0 Post(s)
fingas74 previously said: View Post
I stay on the pavement so can I assume that I won't bend it? Can the front skid be removed without raising the FJ. Can the oil and filter be changed without raising the FJ? Local dealers don't have one to look at. Oil, filter, tire rotation,and drive shaft lub are about all the maintenance the FJ would seem to need? Would like to keep it DIY and avoid the dealer.
Thanks
Tom
Jensent is offline
post #6 of 11 (permalink) Old 12-17-2011, 03:57 AM
fingas74's Avatar
Quoted: 15 Post(s)
Thanks
Tom
You likely won't bend it then. You can get the skid plate off on a stock vehicle without raising it but it is a little tight.
fingas74 is offline
post #7 of 11 (permalink) Old 01-04-2012, 05:04 PM
Quoted: 0 Post(s)
Thanks
Tom
If you stay on pavement, why do you need a skid plate...or an FJ?
Believe nothing you hear and only half of what you see
FJ-Hutch is offline
post #8 of 11 (permalink) Old 01-04-2012, 09:34 PM Thread Starter
Quoted: 0 Post(s)
FJ-Hutch previously said: View Post
My wife likes them and they have a vin. number that starts with "J".
Thanks
Tom
Jensent is offline
post #9 of 11 (permalink) Old 04-15-2012, 10:44 AM
Quoted: 0 Post(s)
////There's no way to change the filter without dropping the front skid on 2010+ FJ's. It's not really a big deal - just 4 bolts and it's off. ////
Glad I found this, I was looking yesterday on my red TTSE for the same thing and discovered the new location seems much harder than the previous high up location. Wonder why the change?
Steve.
firensteel is offline
post #10 of 11 (permalink) Old 04-15-2012, 12:47 PM
shadyvito's Avatar
Quoted: 5 Post(s)
Send a message via Skype™ to shadyvito
Thank God I have an 07! My stock skid plate took two pry bars, a hammer, and an hour to get back on. Yesterday I had to drill out two bolts that I broke taking off my All Pro skid plate to change my front dif oil. That's dented up pretty good so it took a little to get it lined up again. They way I wheel, changing the oil would really be a pain in the ass so I don't know what Toyota was thinking putting it down there.
shadyvito is offline
Human Verification
