suprteck previously said:
There is a gasket between the y pipe and the muffler. When i installed mines i got a leak there because i didnt swap over the gasket... It is metal colored and blends into the pipes so i missed it the first time
This gasket is metal then? If it kinda sticks out, I guess i missed it cause it remained on the header end of the exhaust. I didn't find anything attached to the muffler end. I thought it was formed that way cause even after banging on it, it didn't budge. That gasket along with the spring loaded bolts allow some play at that joint. Pretty nice.
Anyway, I ended up ordering the 2.5" stepped band clamps from Jegs. I redid the clamps but there is still some play, although a bit less than before. I'll let people know when I get the clamps. Although it looked like there shouldn't be much of any leaks from the joint before the muffler.
Does the JBA exhaust have a bit of a burbling, snarling, aggressive-cam-like note at WOT? Maybe I am mistaking this for an exhaust leak?
