Go Back   Toyota FJ Cruiser Forum > Toyota FJ Cruiser Discussion > Maintenance Tech
Old 04-29-2008, 08:07 PM   #41 (permalink)
Chrs's Avatar
Member Number: 5074
Send a message via AIM to Chrs Send a message via MSN to Chrs Send a message via Yahoo to Chrs
Re: JBA Exhaust Installation Help
t0ked previously said: View Post
Well, at that joint, that's as good as you're gonna get it. Aside from using another gasket there and completely bolting it up, you really can't do much else (not good as there will be absolutely no give at all). You sure you have leaks there? Mine doesn't leak there at all... its all the other joints that are leaking though.
Yeah, I waved my hand around the area and there's hot air blowing out from part of the top. I'm not really sure what to do, so I will bring it to a muffler shop when I have some time.
2007 "Virgin" Shortbus - Passenger Armrest · 2008 Sun Visors · A-Trac Switch
Chrs is online now
Old 05-01-2008, 06:28 PM   #42 (permalink)
Chrs's Avatar
Member Number: 5074
Are there any negative effects to small leaks? I have a 8-hour roundtrip drive this weekend. Everyone once in awhile i hear some fluttering, but it goes away.
Chrs is online now
Old 05-02-2008, 10:38 AM   #43 (permalink)
DEWFPO's Avatar
Member Number: 7505
Very small leaks usually are not a problem unless the leak is blowing hot exhaust gases on some part of your vehicle that will cause a problem (as in start a fire, melt the fuel line, or melt wires, etc...) I would definitely check all your leaks before I left and make sure I felt comfortable. The hot exhaust gases coming our of the cats can be as high as 1500 degrees F under certain conditions. And of course, carry a fire extinguisher.
DEWFPO
"Enjoying the Journey"
DEWFPO is offline
Old 05-02-2008, 08:13 PM   #44 (permalink)
Chrs's Avatar
Member Number: 5074
DEWFPO previously said: View Post
DEWFPO
I checked again and the leaks are small. The cause of the fluttering noise is due to the tailpipe touching the frame/"axle" thingy. I can move the tailpipe temporarily, but it eventually moves back. I may try getting the clamps from JEGS before I go to a muffler shop.
Chrs is online now
Old 05-06-2008, 05:27 PM   #45 (permalink)
Member Number: 15627
Send a message via AIM to t0ked
Yup. The bend pipe falling back down and touching the frame cross member was my initial problem and the main reason for my original post. I eventually solved it by cutting 4 small (1/4") grooves into the muffler end of the pipe and then using the clamps. I wrapped some mufflertape around the cut pipe to make sure there were no leaks (shouldn't be since the bend pipe inserts more than 1/4") and then tightening the clamps. I only used the JEGs band clamp on the joint prior to the muffler and it seems to have solved the leak.
2008 Toyota FJ Cruiser (Black Diamond)
2007 Toyota Camry
1993 Lexus SC300 (Diamond White Pearl)
1999 Dodge Caravan
t0ked is offline
Old 07-30-2008, 03:08 PM   #46 (permalink)
Member Number: 15428
After installing this exhaust, it's clear that the install is easier if you disregard part of JBA's instructions. It was far easier to remove the rear-most bolts (which hold the tailpipe to the muffler) by first unbolting the spring loaded bolts and taking the entire system off the hangers. This provides more room to get to the difficult to remove bolts on the tailpipe.
It sounds great! Quiet at idle, by 1500rpm it has a nice groan, throaty from 3000 rpm and up.
I'm unhappy the muffler isn't a perfect bolt-on and JBA even recommends welding the parts together, but with a little patience you can get the system in place and it will not bump against the frame or suspension components. It was worthwhile to get one person pushing the muffler up while the other person gets the tailpipe routed and placed to avoid rubbing. So far, the only spot with a leak, and it's minor, is at the back end of the muffler can. It really only leaks at medium throttle, at idle and WOT it's flowing right through with no leak.
Hopefully running it for a couple hours offroad today will heat it up and get the parts to expand and bind a tiny bit more. Plus a little mud on the pipes might seal it up to
superbox is offline
Old 07-31-2008, 09:33 AM   #47 (permalink)
RomaBoy's Avatar
Member Number: 2866
[quote=superbox;1068623]After installing this exhaust, it's clear that the install is easier if you disregard part of JBA's instructions. It was far easier to remove the rear-most bolts (which hold the tailpipe to the muffler) by first unbolting the spring loaded bolts and taking the entire system off the hangers. This provides more room to get to the difficult to remove bolts on the tailpipe.
QUOTE]
That's a great tip! I bet you could can get an impact gun on those tailpipe bolts by doing it that way.
RomaBoy is offline
