Go Back   Toyota FJ Cruiser Forum > Toyota FJ Cruiser Discussion > Maintenance Tech
Old 04-13-2008, 07:36 PM   #1 (permalink)
Member Number: 15627
Send a message via AIM to t0ked
JBA Exhaust Installation Help
I think I was one of the last guys to get in on the groupbuy for this exhaust. I love the sound and the look. The problem I'm having is the installation.
So this question goes to all those who have this exhaust. I pieced all the parts together and used the clamps. I've tightened them down as tight as they will go... but there is still play between the pipes. This morning I turned on the FJ and saw condensation dripping out of the exhaust at 3 different areas so I know there are leaks. At WOT, it definitely sounds like there are exhaust leaks.
I did as the instructions stated. I slip one end of the pipe over the other and then clamp them with the parts provided, but even tightened fully, I can slide the pipes apart. I had to rig something up to keep the tail piece correctly aimed. Am I doing something wrong? I really don't want to weld everything, but it seems that is the direction I will need to go. Any help is appreciated.
BTW, taking out the OEM exhaust was one of the most agonizing things I've ever done. Those two bolts by the upturm passed the muffler is ridiculous. Even after I removed it, I couldn't get them off with air tools. WTF?
2008 Toyota FJ Cruiser (Black Diamond)
2007 Toyota Camry
1993 Lexus SC300 (Diamond White Pearl)
1999 Dodge Caravan
t0ked is offline
Old 04-13-2008, 11:47 PM   #2 (permalink)
Banned
Member Number: 15750
Re: JBA Exhaust Installation Help
Well, it seems that since you didn't take the stock exhaust apart fully that you didn't put the exhaust gaskets back on to seal it up. I know coming from the Y pipe there's a gasket and then the muffler just goes together with the U clamps on either side. It actually would be best to weld them for a better fit which is what I might do so I don't have to worry about mine freaking rattling all the time.
fj_tonka_toy09 is offline
Old 04-14-2008, 01:35 AM   #3 (permalink)
FJKoji's Avatar
Member Number: 13609
You sure you have your u-clamps tightened as far as they will go?
I would give it another go. I tightened mine too much and ended up bending one of the pipes so with enough elbow grease I am sure you can tighten it further.
You are right though, that one set of bolts was impossible to get off. I ended up using a sawzall (thanks FJoel!) to cut the pipe in half to get it off. I wasn't aware of any gaskets on the OEM catback . . . ?
'08 Off Road Pkg. MT
TRD CAI|JBA CatBack Exhaust|TBS|All-Pro AirDam w/ PIAA 540s & Soletech Spots
Alpine IVA-W205|Blackbird II Navigation|Bluetooth Interface|Alpine MRP-450 Amp|Infinty 10" Sub| Infinity Reference 3.5"
Next to Get: Sliders, Bumper
FJKoji is online now
Old 04-14-2008, 05:56 AM   #4 (permalink)
There are no gaskets in the stock exhaust set up so I don't know about that. But, yeah, when I took the JBA back apart, I saw that the larger diameter pipe had bent due to the clamps. It's just that the inner pipe still has play! Oh well. Looks like some pipe flaring and welding it is then. And I don't have any rattling it's just that right now there are numerous exhaust leaks.
2007 Toyota Camry
1999 Dodge Caravan
t0ked is offline
Old 04-14-2008, 06:16 AM   #5 (permalink)
FJ666's Avatar
Member Number: 16040
I installed mine and no leaks so far. I will have another look today. I do find it rubs on the frame at the back. I'm going to try to fix that today.
Those two bolts are impossible to get off. I wanted to save the OEM exhaust but ended up cutting mine off too.
My money smells like Strippers.
FJ666 is offline
Old 04-14-2008, 06:59 AM   #6 (permalink)
RomaBoy's Avatar
Member Number: 2866
t0ked previously said: View Post
I never want to weld anything together either in case I want to take it apart later. This is what you need and I have used them with great success. JEGS Preformed Stainless Steel Exhaust Band Clamps - JEGS
RomaBoy is offline
Old 04-14-2008, 07:34 AM   #7 (permalink)
Yeah, I don't want to weld it together either. But those clamps from Jegs looks promising, only thing is they don't make bent ones which I'll need... ugh.
2007 Toyota Camry
1999 Dodge Caravan
t0ked is offline
Old 04-14-2008, 08:55 AM   #8 (permalink)
RomaBoy's Avatar
Member Number: 2866
Hey Bro, I have the same JBA cat back system. Where everything connects is straight so why do you need bent clamps?
RomaBoy is offline
Old 04-14-2008, 10:27 AM   #9 (permalink)
Regud's Avatar
Member Number: 14560
RomaBoy - Did you use 3 of the JEGS 2" clamps? I am installing my JBA exhaust later this week and think these clamps are the better way to go.
Regud is offline
Old 04-14-2008, 10:43 AM   #10 (permalink)
FJKoji's Avatar
FJ666 previously said: View Post
I have a little bit of rub/rattle on mine as well. Just trying to figure out how to fix that.
