Go Back   Toyota FJ Cruiser Forum > Toyota FJ Cruiser Discussion > Maintenance Tech
Old 04-22-2008, 03:24 PM   #21 (permalink)
wrigman's Avatar
Member Number: 3274
Send a message via Yahoo to wrigman
Re: MAF Sensor Maintenance
I have been using the K&N drop in in Nala almost from the start. I also use them in my truck, motorcycle and race karts. I have never had a problem with them or the oil used on them. I clean, then reoil the filter lightly, let the filter sit for about a half an hour, then fill in the lite area's with another lite spray, then I let the filter sit for another half an hour before I apaly a lite coat of filter grease around the seal. Then I install the filter. I check the filter after each off road run and regrease the seal when I install the filter. We have 23,000 miles on the FJ and I have only cleaned the filter once.
Just the way I do things, I could be wrong. one thing for sure, i will be pulling the MAF to take a look at it and clean it if needed.
"A common mistake that people make when trying to design something completely foolproof is, to underestimate the ingenuity of complete fools"
SF, A/T, Conv. Pac.,Aeroflow HLC's, Demello sliders, Demello Skid plate, OME 2" lift, BFG A/T, K&N filter, Magnaflow exhaust, KC 100 watt and 130 watt slim lights, Two tone air horn,Demello prerunner bumper, rear tow hitch,Allpro LCA's and Skids, Mile marker PE8000 winch, Amsteel blue winch rope, Delrin fairlead rollers.
Treadlightly member.
wrigman is offline
Old 04-22-2008, 03:44 PM   #22 (permalink)
Member Number: 16009
can someone please post pics of exactly where to clean.....this is somethingthat I would like to keep on periodically as well but dont know where you guys are talking about......please elaborate in more detail(maybe a couple good pics) and how much spray and where to spray exactly.....thanks in advance
survivorman is offline
Old 04-22-2008, 04:15 PM   #23 (permalink)
wrigman's Avatar
Member Number: 3274
survivorman previously said: View Post
Look at Larry's post. He put a circle around the part under the engine cover.
wrigman is offline
Old 04-22-2008, 04:47 PM   #24 (permalink)
Pacific Coast Moderator
uphill's Avatar
Member Number: 10461
wrigman previously said: View Post
Me too. 27,000 miles later I changed my mind. The Scorpion eats a lot of trail dust and even though the OEM filters are more expensive because they need to be changed far more often, I think the filter without oil is the way I'm going to go.
"L'audace, L'audace, Toujours l'audace!"
THE SCORPION
véhicule tout terrain scorpion
скорпион сервисное транспортное средство
โตโยต้า จัตุรงค์ ยาง ล้อเลื่อน แมงป่อง
vier Radantrieb vom Straßenfahrzeug Skorpion
automóvil cuatro rueda Escorpión
蠍子, 豐田越野汽車
Нэвтрүүлэгч хилэнцэт хорхой
macchina fuoristrada lo Scorpione
uphill is offline
Old 04-22-2008, 05:04 PM   #25 (permalink)
mattmainster's Avatar
Member Number: 11822
Send a message via AIM to mattmainster
Can this cause poor gas mileage? I mean, worse that normal...
Snorkeled, Icons all the way around...and some other stuff.
mattmainster is offline
Old 04-22-2008, 05:32 PM   #26 (permalink)
puulboy's Avatar
Member Number: 8494
So.. let me get this right. If you have to clean your MAF sensor because of dust on it... Where does the dust end up that doesn't get stuck to the MAF sensor?
That was rhetorical.
The K&N filter does not keep dust from entering your motor. The filtering ability is not good enough for dusty conditions. Period
Maybe thats why some people run pre-filters.
Stock is better but not the best either.
You should inspect your intake occasionally for excessive dust. Thats why I pulled the K&N I had and threw it in the garbage.
I havent had a dust issue since I installed the True Flow. My intake is clean . That was my no. 1 reason for installing it
Did someone say RAFFLE ???
AZFJ faithful
Member build page
http://www.fjcruiserforums.com/forum...other-gal.html
puulboy is offline
Old 04-22-2008, 05:42 PM   #27 (permalink)
uphill's Avatar
mattmainster previously said: View Post
Yes. No question about it.
puulboy previously said: View Post
I thought that the snorkel would help. I'm sure it will. I have nothing against the CAI's except that they occupy so much SPACE under the hood. I need another few cubic feet of space inside the FJ's hood - to add a compressor, a CAI/pre-filter, and whatever else I come up with. I already have the aux battery and a fuse block on top of the R/F tire well.
THE SCORPION
蠍子, 豐田越野汽車
uphill is offline
Old 04-22-2008, 07:09 PM   #28 (permalink)
ok....I saw the pic but what I need to know is do you just get to the sensor and spray it off? just basically spray all over and your done?
Old 04-22-2008, 08:07 PM   #29 (permalink)
targa88's Avatar
Member Number: 11127
Send a message via Skype™ to targa88
Larry,
since you have the standard air box set up - you might want to think about the "cyclone pre-cleaner" helps with reducing the dust up into the airbox.
Plus it does not take up a lot of place....
targa88 is offline
Old 04-22-2008, 08:10 PM   #30 (permalink)
Custom User Title
DominicG's Avatar
Member Number: 1647
targa88 previously said: View Post
Larry,
I don't think the cyclone will be possible with the snorkel.
DominicG is online now
