Go Back   Toyota FJ Cruiser Forum > Toyota FJ Cruiser Discussion > Maintenance Tech
Old 05-17-2008, 09:45 AM   #51 (permalink)
MountainMan's Avatar
Member Number: 8491
Re: MAF Sensor Maintenance
great tid bit O info, thanks Uphill!
MountainMan Johnson (blog) WØOZY (447.15 / 146.46 / 147.225) MEMBER: FJ Cruiser Club : NRA : BSA : ARES
Mods: Tint : ClearPlex : Shovel & Axe w/ FourTrex Mount : M-Pac Storage : Blackened Trim : Bandi Mount : Diamond NR770 Antenna : Yaesu VX-7R : Yakima PowderHound : DeMello Round Sliders : DRing Hitch : Recovery Strap : Next_Cooper STT's
MountainMan is offline
Old 05-22-2008, 02:49 AM   #52 (permalink)
layonnn's Avatar
Member Number: 10006
"The MAF uses a heated wire or film which is stretched across the incoming air flow. The element requires more electrical current to maintain its temperature, as the amount of intake air flow increases. By measuring the amount of current necessary to maintain the temperature of the wire or film, the control unit can calculate the volume of air entering the engine. Since the volume of air entering the engine is directly proportional to the amount of engine load, the ECM can determine the operating load of the engine, by monitoring the MAF signal wire."
This is some info that i found. If it had dirt around the MAF, it would def. make the engine run not like it should
Layton
2007 FJ Cruiser 5AT 4x4
Voodoo Blue
"God forgives...rocks don't"
layonnn is online now
Old 06-28-2008, 01:46 PM   #53 (permalink)
Tankota's Avatar
Member Number: 3884
wrigman previously said: View Post
Look at the sensor, there is a hole in it. THAT IS NOT THE SENSOR!! The sensor looks like a match stick.
That is not correct. The sensor that looks like a match stick is the temperature sensor, it reads the incoming air temp. The air flow sensor is in fact down in the holes, it's two very thin sensor wires that are stretched across the opening down there.. These are the platinum hot wires. Do not stick anything down there! The can break real easy, and then you are SOL. Most of the problems with the MAF are these two thin wires getting coated and gummed up... You want to carefully spray MAF cleaner down there and get those wires cleaned. Make sure what ever cleaner you use is an electronics type cleaner, and is rated "plastic safe". Best bet is the CRC MAF cleaner spray that can be found at most auto parts stores. DO NOT USE carb cleaner or brake cleaner.
David Hale
2007 Sun Fusion FJ Cruiser - Project T2
Demello Sliders, Icon (DR) Front coilovers, Deaver Rear 2.5 Coils and rear Bilstein 7100 shocks, All Pro HD rear links, 34" Goodyear MT/R's, Bandi Mount, Demello front bumper w/winch, Demello Front Skid plate, 4x150W roof mounted KC's and safari lights, ATRAC-Hack.
2007 Yamaha Grizzly 700fi 4x4
2007 Yaris S-Sedan (DD)
http://www.offroadingadventures.com
TTORA-Socal member #38 TTORA Forum
Trail Crew Member
Tankota is offline
Old 07-10-2008, 06:28 AM   #54 (permalink)
Shiz's Avatar
Member Number: 3261
Look at Larry's post. He put a circle around the part under the engine cover.
do you have to take it out? or jsut spray it where it is??
oops, never mind. saw the answerssss
Shiz is offline
