Go Back   Toyota FJ Cruiser Forum > Toyota FJ Cruiser Discussion > Maintenance Tech
Old 05-14-2008, 09:14 PM   #11 (permalink)
1911's Avatar
Member Number: 4994
Re: How do I check the differential Fluid?
the magnetguy previously said: View Post
because the fill hole on the rear diff is quite high and kind of awkward to get at , what is the easiest way to fill it? extension tube on a funnel , or pump gun or what?
Hand pump and flexible hose; you can buy them at any auto parts store.
also how much oil is enough?? - thanks for any advice!!
Until it runs out of the bottom of the fill hole. If your diff was bone dry (if you could drain every drop) it would take just over three quarts to fill it. Since gear oil is quite viscous, you'll never get all he old stuff out. It helps to drive the truck until fully hot before you change it.
'07 FJC, '91 FJ80, '84 Hilux, TLCA # 16550
I hear mariachi static on my radio, and the tubes they glow in the dark (Warren Zevon)
1911 is offline
Old 05-14-2008, 09:30 PM   #12 (permalink)
DEWFPO's Avatar
Member Number: 7505
X2, between $5-10 and worth every penny.
DEWFPO
"Enjoying the Journey"
DEWFPO is offline
Old 05-15-2008, 10:29 AM   #13 (permalink)
the magnetguy's Avatar
Member Number: 1760
1911 previously said: View Post
thanks kindly for this useful information!! - much appreciated!!
Previous Owner of 9 Toyotas!!
1998 Siver RAV 4 - Daughters car
2003 Silver HIGHLANDER - Wifes car
2007 Silver FJC -My ride
the magnetguy is offline
