Go Back   Toyota FJ Cruiser Forum > Toyota FJ Cruiser Discussion > Maintenance Tech
Old 05-10-2008, 09:25 AM   #21 (permalink)
Member Number: 14683
Re: Differential Gear OIL *TSB*
White Rim previously said: View Post
So the SAE 90 was breakin oil i guess
Could be. I sure hope that none were delivered to very cold areas with a straight 90.
Has there been any apparent pattern to rear diff failure? That is, are they "all over the map" or primarily in cooler climates??
jayman is offline
Old 05-10-2008, 09:25 AM   #22 (permalink)
stringmachine's Avatar
Member Number: 7766
cruiserlarry previously said: View Post
The key here is "synthetic", not just the weight rating change. They most likely decided that the additional protection and temperature reduction provided by synthetic lubricants would help to reduce the occurence of rear diff failures.
I have been using and recommending Redline synthetc lubricants in vehicles for 20+ years, and have yet to see a lube-related failure in any component in all that time. I changed out my FJC soon after I bought it, and when you look at any component that has been run in sythetic oils for any length of time, you can see the difference.
You'll notice more and more OEMs are using synthetics in their transmissions, differentials, and even their engines. This is no accident - it is better for your vehicle.
does Napa, Advance, or Autozone have the redline products?
stringmachine is offline
Old 05-10-2008, 03:01 PM   #23 (permalink)
Member Number: 7766
so do we get a thumbs up for mobil1 75 90 rear diff oil ?
Old 05-11-2008, 10:32 AM   #24 (permalink)
stringmachine previously said: View Post
I would guess so, unless suddenly Toyota gets firm about using this 75W-85. I suppose any chance to deny a warranty claim has to be good for them, right?
jayman is offline
Old 05-13-2008, 01:22 PM   #25 (permalink)
Member Number: 15354
Where do I buy Mobil 1 Delvac gear oil? Any online sources? Thanks,
okayfine is offline
Old 05-13-2008, 01:27 PM   #26 (permalink)
DEWFPO's Avatar
Member Number: 7505
okayfine previously said: View Post
I've never been able to find any viable online sources for it. You basically have to find a Mobil distributor and contact them. They can order it for you if they don't carry it. Some will even ship it to you.
DEWFPO
"Enjoying the Journey"
DEWFPO is offline
