Go Back   Toyota FJ Cruiser Forum > Toyota FJ Cruiser Discussion > Maintenance Tech
Old 05-11-2008, 04:42 PM   #1 (permalink)
Pacific Coast Moderator
uphill's Avatar
Member Number: 10461
Lowrance 540C GPS Maintenance
I always preach about not relying on GPS, etc. And I'm true to my word in that I always have charts/maps and a lensatic compass.
However, I've come to rely on my Lowrance 540C and I love the beast. The Shadow Mount that put it where my R/V mirror was keeps my position in easy view at all times.
In Death Valley a week or so ago, while minding my own business the GPS suddenly stopped tracking.
I saw a "?" in the cursor. The message was "GPS Module not responding".
That never happened before. So I started playing with it. No luck. I fiddled with the antenna on the roof.
The connection seemed to be good. I checked to see how many satellites I was receiving. I couldn't believe my eyes. I was hot on 9 satellites.
So for the rest of the trip I fell back to maps and NEVADAESH, the Death Valley Pathfinder who was leading the group. But I was frustrated, irritated and annoyed.
When I got home I bought some Radio Shack "Precision Electronics Cleaner" and undid the connections in the back of the unit. I sprayed them, let them dry, screwed the connections back together -- and it worked.
So if it doesn't work, blast the electrical connections with cleaner. That might be your problem.
"L'audace, L'audace, Toujours l'audace!"
THE SCORPION
véhicule tout terrain scorpion
скорпион сервисное транспортное средство
โตโยต้า จัตุรงค์ ยาง ล้อเลื่อน แมงป่อง
vier Radantrieb vom Straßenfahrzeug Skorpion
automóvil cuatro rueda Escorpión
蠍子, 豐田越野汽車
Нэвтрүүлэгч хилэнцэт хорхой
macchina fuoristrada lo Scorpione
uphill is offline
Old 05-11-2008, 11:55 PM   #2 (permalink)
StHarris's Avatar
Member Number: 4633
Send a message via AIM to StHarris Send a message via Yahoo to StHarris
Re: Lowrance 540C GPS Maintenance
Glad you got it working again, and it was only a bad connection . . . not a bad unit.
07 Sun Fusion
TLCA # 16633
StHarris is offline
Old 05-12-2008, 06:35 AM   #3 (permalink)
puulboy's Avatar
Member Number: 8494
In the instructions, it says to use dielectric grease for each union, Did you do that initially? Just curious if that is attracting dust.
thanks
Don
Did someone say RAFFLE ???
AZFJ faithful
Member build page
http://www.fjcruiserforums.com/forum...other-gal.html
puulboy is offline
Old 05-16-2008, 10:54 AM   #4 (permalink)
uphill's Avatar
puulboy previously said: View Post
thanks
Don
I think that was the problem. I used the grease at the point of installation and then for the past year or so, I've been running in horrible southwestern dust. I used the contact cleaner to clean the connection points and then put the can in the toolbox I keep in the rig.
THE SCORPION
蠍子, 豐田越野汽車
uphill is offline
Old 05-16-2008, 11:00 AM   #5 (permalink)
JoeUser's Avatar
Member Number: 15334
I had a similar thing happen on my Garmin 2620, which I use on my Harley. It's exposed to the elements, and it started behaving strangely (not accepting inputs, randomly losing route info, popping into screen alignment mode, etc.).
Since the connector is not sealed, corrosion was causing a poor connection. Cleaned the connector contacts on the cable and on the GPS itself, and all was normal again.
So, keeping a small bottle of denatured alcohol on the bike from now on. Lesson learned...
Dennis' Titanium:
'08 Titanium 4X4; AT; LD; A-Trac; Uniden PC78XLT, Bandi mount, 4' whip; Toyota extra horn mod; Predator step rails; no mud flaps; LT285/70/R17 Hankook Dynapro MT tars; 3" Lift (OME 884 front coils & N140S shocks, ToyTech Medium rear coils, OME N71E rear shocks); All-Phase rear diff skid; SCUBA breather mod; Steel sway bar collars; All-Pro sway bar links, rear shock skids, and lower link skids; Digger upper and lower rear links; Rasta4x4 skids; Toytec 1" diff drop kit (as soon as I get around to spacing the skids)
JoeUser is offline
