Go Back   Toyota FJ Cruiser Forum > Toyota FJ Cruiser Discussion > Maintenance Tech
Old 06-01-2008, 12:07 PM   #21 (permalink)
DEWFPO's Avatar
Member Number: 7505
Re: I had dirty rear differential oil!
I have a small qt. hand pump now. Costs about $5-7 at most parts places.
Before that I used to use a long tube, stick it in the fill port and run the other end of the tube to the outside of the vehicle. I'd stick a funnel in the end of the tube and tie the top of the funnel to the side mirror with a string. Then I would pour in the required amount of lube by standing alongside the vehicle. After putting in the last bit, I'd climb back under the vehicle with my needle nosed pliers and wait for the overflow, then I'd pinch the tube and pull it out of whatever I was filling and stick it into one of the empty lube bottles to drain the remainder into. Gravity works great.
DEWFPO
"Enjoying the Journey"
DEWFPO is offline
Old 06-01-2008, 08:08 PM   #22 (permalink)
Member Number: 14671
Blown383 previously said: View Post
Quick question....where is the drain plug for the transfer case? I tired looking at the FJ factory manuals and it doesn't show where its located.
-B
Find the transfer case. If you cannot find it, follow the rear drive shaft towards the front of the vehicle. It will end at the TC. Here, you will see 2 large bolts (these bolts will be facing the rear of the vehicle), 24mm or 15/16". I was able to get under the vehicle and drain/refill the TC when it was stock.
Remember, always remove the refill (top) bolt first.
2007 VooDoo Blue / 5AT / 4WD
Rear Diff Hack (Works in 2HI & 4HI) / Rear Diff + ATrac Hack
Rough Country 3" Lift
KU4IY (Yaesu FT-7800)
SVTim is offline
Old 06-02-2008, 02:04 AM   #23 (permalink)
Member Number: 11438
Send a message via AIM to Blown383
SVTim previously said: View Post
When I crawled underneath the car it was pretty obvious. LOL! So after after changing out the front & rear diff, and the transfer case I ended up using 5.5 quarts. Is that normal?
-B
08' FJ Cruiser 4x4 AT, CQ, OF - Titanium Silver.
97' Z28 - M6 - ATI D1 Procharger, FMIC, LE2 heads, Bret Bauer/Llyod Elliot bump stick, SCAT 4340 383 rotating assembly, H-beam rods, splayed 4 bolt main caps, Ractronix dual intank fuel system, 83lbs injectors.
Motor sitting on stand and car in ONE BILLION pieces.
Blown383 is offline
Old 06-02-2008, 06:34 AM   #24 (permalink)
-B
That sounds normal. I used nearly 6 full quarts, but I did allow everything to drain for an hour.
SVTim is offline
Old 06-02-2008, 01:13 PM   #25 (permalink)
Member Number: 11685
-B
Here is a link to a thread that will show a pic of the transfer case fill & drain plugs...
changing truck fluids...need help
Peromyscus is offline
Old 07-09-2008, 08:04 PM   #26 (permalink)
Crotalus's Avatar
Member Number: 15654
I just changed my rear differential oil for the first time with Mobil 1 Synthetic 75W-90. The old oil was very dirty, slightly milky, with sludge and some metal fragments/shavings - YUCK! I've been in some water and at just under 20k miles, I was a bit nervous about how bad it would be - wish I would have changed it earlier, but it's done now. I will definitely be changing my diff fluid at least every 10k from now on and am also doing the scuba mod.
Hisssssssssssssssss!!!
-Crotalus
2007 Voodoo Blue 6 MT
Rear differential and locker scuba mod
A-Trac switch installed
Custom CB antenna mount
Custom tube bumper in the works...
Crotalus is offline
Old 07-10-2008, 11:51 AM   #27 (permalink)
Thermal_Scorpion's Avatar
Member Number: 8817
I just had my diffs done yesterday. The fluid was dark greyto light black but not milky. No metal shavings on the magnets either.
What level of fluid darkness should cause alarm?
Thanks.
"Trailstalker," 07 TitMet, AT, Opt 1, Garmin 60CSX, PIAA Extremes, Aeroflo Light Shields, Rear Gate Axe Mount, Trail Gear Rocksliders, All-Pro IFS Skid and Transmission Skid, BFG KM2 285/70/17, Scan Gauge II, Black KC Slimlite Fogs, Black KC Slimlite Driving Lights, PIAA 510 XT SMR, Fourtreks Hi-Lift and Dual Tool Mounts, Midland 75-822 CB, Bandi Mount with Firestick Anetnna, AR Vice Rims, aFe CAI, OME Medium Lift, SCUBA Driver Mod, Road Armor Bullbar Bumper with Warn 9.5Xp, Decepticon Emblems.
Thermal_Scorpion is offline
Old 07-10-2008, 01:16 PM   #28 (permalink)
spincycle's Avatar
Member Number: 9041
Thermal_Scorpion previously said: View Post
Thanks.
Ditto this. Mine was dark. Spoke to a tech who I trust who indicated no alarm about it, but noted the darkness in his writeup.
I feel like I wanna add some of my 1" diameter ultra-strong neodymium mags to the side of he diffs, see what happens.
TLCA#17822 / FCC:KD0ECN
'07-6MT-FJC...and a whole BUNCHA stuff.
My thanks to Budbuilt, Lucrum, URD, Tuffy, Springtail, KC, BFG, Valentine One, Cobra,
Engel, BFG, Cobra, Yaesu
Protest the end of poitical dialog by contacting
your favorite moderator(s)!
spincycle is offline
Old 07-10-2008, 01:39 PM   #29 (permalink)
bartt's Avatar
Member Number: 1660
spincycle previously said: View Post
No need for that, the drain plugs are magnetized.
07 Titanium loaded..
Current mods: scuba breathers, OME883's & Bilstein513's, BFG KM2's, Bridgestone Revos, Trailgear Sliders, K&N Drop in, 08 side visors, 35% tint, Redline gear oil, Atrac hack, mini-ITX PC (GPS & wardriving), upgraded speakers, custom rear door sub, custom air dam w/ hella spots and surf rack, grill mounted hella driving and fog lites, air horns, solar batter charger, rear 12V outlet, block heater, painted stock alloys (1 set black, 1 set graphite)..
bartt is online now
Old 07-10-2008, 02:50 PM   #30 (permalink)
DEWFPO's Avatar
Member Number: 7505
Thanks.
The color isn't really all that important. If it's dark, it typically means the fluid is doing it job by suspending the fine particles in it. What you are mainly looking for is material on the magnet, the 'feel' of the lube between your fingers and the consistency (as compared to fresh).
DEWFPO
DEWFPO is offline
