Too much grease in the slip joint - Toyota FJ Cruiser Forum
Maintenance Tech
 4Likes
post #1 of 15 (permalink) Old 03-16-2017, 02:29 PM Thread Starter
manoweb's Avatar
Quoted: 66 Post(s)
Hello I was greasing the shafts after changing differential and transmission fluids (90k miles) and everything was going OK. I fully realize that the slip joints only needs a few squeezes of the grease gun, while the U-joints like to have some grease come out. However, my brain was on autopilot and I started pumping into the forward slip joint, I must have pumped 12-14 times before I realized.
I removed the zerk but nothing came out. The FJ is on 4 jack stands and there is no weight on the front axle, all the tires have been removed; it seems the front slip joint is fully "compressed" in this configuration. Am I OK or should I do something to avoid hydro-lock the slip joint?
PS now that I have the FJ up on jack stands, tires removed, what should I look for as preventive maintenance, other than what's written in the manual?
Thank you!
as
KE7JDE/IZ2GMV
manoweb is offline
post #2 of 15 (permalink) Old 03-16-2017, 02:52 PM
chriskrossapplesauce's Avatar
Location: Dayton, OH or Silver Lake, WI or Sugar Grove, IL
Quoted: 567 Post(s)
Re: Too much grease in the slip joint
I did something similar and probably gave it just as many pumps. That was 8 months and 10k miles ago. So far it's been good.
Young, dumb, and blunt - Chris
chriskrossapplesauce is offline
post #3 of 15 (permalink) Old 03-16-2017, 03:04 PM Thread Starter
manoweb's Avatar
Quoted: 66 Post(s)
I should add that I "forgot" to grease the shafts for the last... well I cannot really remember. So maybe I'm OK an from now on I will grease more regularly and not add so much grease any more of course.
KE7JDE/IZ2GMV
manoweb is offline
post #4 of 15 (permalink) Old 03-16-2017, 03:11 PM
Quoted: 567 Post(s)
manoweb previously said: View Post
As far as I know, when I did mine a few months back, it was the first time my FJ had ever gotten its shaft lubed I can't guarantee it'll be good but what else could you do short of removing the shaft and cleaning out all the extra grease?
post #5 of 15 (permalink) Old 03-16-2017, 03:25 PM
gearwrench's Avatar
Quoted: 296 Post(s)
I actually had this happen once while lubing a slip joint on a manual transmission Tacoma pickup, it actually shifted the engine and transmission and my customer couldn't shift into all the gears because of it. I was using an air operated grease gun so it had more power than a hand operated gun. I used a pick and depressed the ball in the grease fitting to bleed some grease out. This only happened to me that one time so it may have been a one time thing since I had lubed many drivelines before and after it.
gearwrench is offline
post #6 of 15 (permalink) Old 03-16-2017, 03:43 PM Thread Starter
manoweb's Avatar
Quoted: 66 Post(s)
Well in my case I removed the zerk with a 7mm socket, and nothing came out. But, I do not have the vehicle on its wheels yet and I cannot drive it around
KE7JDE/IZ2GMV
manoweb is offline
post #7 of 15 (permalink) Old 03-16-2017, 03:48 PM
bazross's Avatar
Quoted: 1349 Post(s)
G'day,
I used to think that.... 2-3 squirts .... but about 12 months ago, i filled it deliberately... till old black grease was oozing out past the seal...
didn't hydro lock it..and no rear end bump since....
so I think you would be ok, infact i would suggest if you have not done it in a while, keep filling it till the old is forced out...
Cheers
Baz
FatJohnson likes this.
bazross is offline
post #8 of 15 (permalink) Old 03-16-2017, 04:00 PM
NW FJC's Avatar
Quoted: 289 Post(s)
I filled mine once upon a time with no ill side effects before I knew..... I like the idea of leaving the zerk out for a while to let any extra grease out if you don't want to pull the driveline.
_____________________________________________
Nothing screams poor craftsmanship more than wrinkles in your duct tape....
NW FJC is offline
post #9 of 15 (permalink) Old 03-16-2017, 04:27 PM
Quoted: 23 Post(s)
i just took my fj in for the 50k maintenance, rotation, tires, etc. do you know if the dealership does the greasing on these zerk fittings as part of the maintenance?
Geo Ang is offline
post #10 of 15 (permalink) Old 03-16-2017, 04:31 PM
CurbCrawler's Avatar
Quoted: 141 Post(s)
Don't worry it's really not meant to be an air tight seal, once the shaft rotates and slides in and out a bit it will work some of the grease out, but is almost sounds like the grease gun ran out before it was packed to the max? I grease mine until it oozes a bit every time. The seal is really for prevention of large amounts of moisture from entering directly as well as dust and debris particles.
The reason why we retain memories is because we are not caught in a time loop. The reason why we are not caught in a time loop is because it is not possible to go backwards in time only forward!
*CurbCrawler fabricated hidden front receiver.
*CurbCrawler fabricated Hi-Lift receiver mount.
*CurbCrawler fabricated SS dual battery tray & Walmart Battery.
*CurbCrawler fabricated 4-Gauge dash pod.
*CurbCrawler fabricated Aux fuse/relay panel.
Gibson cat-back exhaust (Dyno Proven)
Complete set of aluminum skid plates.
Receiver mounted 9k-lb rear winch.
Hayden trans cooler w/electric fan.
Factory rock rails.
Moon roof.
LED fog & backup lights.
Husky mats: front, center & rear.
CurbCrawler is offline
Human Verification
