Changing rotors - Toyota FJ Cruiser Forum
Maintenance Tech
post #1 of 25 (permalink) Old 08-07-2008, 10:56 AM Thread Starter
Breakoff's Avatar
Quoted: 0 Post(s)
Changing rotors
I was wondering everyones opinion on the subject of changing rotors every time you change pads. I have always put new rotors on at the same time mostly because for $25 dollars per rotor why not. I may be completely wrong but I have done many a brake job and I always thought this was the right way of doing it.
The rotors wear unevenly leaving grooves, putting new pads on old rotors means that the pads would only come into contact with the rotors at the high spots of the grooves until the pads were worn down. A friend of mine asked me to replace his brakes but he wont buy new rotors because his father told him it was not needed even though his brakes are so worn that they are grinding.
I just wanted some input from a different point of view.
Breakoff is offline
post #2 of 25 (permalink) Old 08-07-2008, 11:38 AM
Mikey D.'s Avatar
Quoted: 1353 Post(s)
Re: Changing rotors
I've always had my rotors 'turned-down' when the pads needed replacement. Being that my vehicles were usually leased that meant only one brake job per contract. A rule of thumb: if a rotor is 'turned-down' once for a brake job then it should be replaced at the next brake job. Only one 'turn-down' per rotor.
Just my .02!
Mike
In Memoriam: NYPD DAOS/NYS OIG - #77 and all of our fallen LEO's!
Pancreatic Cancer - want to learn ALL about the tests to detect it? Well, so would I...so would I!
Freedom isn't free...thank you Veterans!
9-11-01...NEVER FORGET!
R.I.P. SEATTLE MIKE - JOE S. - VINNY D. - ROBOTUSSIN!
...and God Bless Donald Trump!
Mikey D. is offline
post #3 of 25 (permalink) Old 08-07-2008, 11:49 AM
FJ FunJunkie's Avatar
Quoted: 1 Post(s)
Re: Changing rotors
I've always got mine turned for the first 2 brake pad changes. after that they are usually too thin and need to be replaced but it depends on the type of vehicle and the thickness of the rotors originally. as for the FJ, I brought mine in for the brake noise TSB at around 30K and they replaced pads and rotors.
http://www.fjcruiserforums.com/forums/signaturepics/sigpic7470_2.gif
cnckart previously said: View Post
Yup thieves are stupid, that's why they are thieves.
FJ FunJunkie is offline
post #4 of 25 (permalink) Old 08-07-2008, 12:16 PM
kokopelli's Avatar
Quoted: 4 Post(s)
Re: Changing rotors
As the others have said; most people have the rotors turned, but there's a limit on how far you can go. Personally, I installed many, many pads/shoes and not turned or replaced rotors/drums.
On my DD, I would probably replace them as you have said. The last time I had a dealer do my brakes I watched as they took my rotors off and threw them in a big pile. I walked out and asked WTF are you doing with my parts. Dude said a truck comes by and picks them up every two weeks... So I say, then what are you going to put on my truck? He points to another rusty pile and says those have already been turned...
I had them replace my originals, left and never returned. From that point on, I purchased new ones myself and watched them being installed.. Ron
Breakoff previously said: View Post
08 SS, Kokopelli decals, SS valve stem caps, 35PSI COLD and exhaust tip
Ain't no pockets on a shroud
kokopelli is offline
post #5 of 25 (permalink) Old 08-07-2008, 12:21 PM
landy's Avatar
Quoted: 11 Post(s)
Re: Changing rotors
If your friend's brakes are worn to the point of grinding, it could be causing damage to the rotors. This has happened to me. You won't really know until you get in there. Have your friend buy all the components for a worst-case scenario and if the rotors turn out to be okay then you don't have to replace them. Just my $.02
Landy
Support these fine vendors!
TRDParts4U
Demello Offroad
Ricochet
Icon Vehicle Dynamics
landy is offline
post #6 of 25 (permalink) Old 08-07-2008, 12:23 PM
FJDunkball's Avatar
Quoted: 0 Post(s)
Re: Changing rotors
My first brake job I am going to put on the TRD brake rotors and pads. I think it's real important to have good breaks that you can count on especially if you drive with a trailer or lots of city driving. Plus my most precious cargo rides in this rig everyday and thats my wife.
My .02
FJDunkball
Using my FJ to enjoy the environment and God's creations.
FJDunkball is offline
post #7 of 25 (permalink) Old 08-07-2008, 12:32 PM
mikey's Avatar
Quoted: 902 Post(s)
Re: Changing rotors
I replace my rotors. I have had rotors turned in the past that were poorly (machined uneavenly) done which resulted in a pulsing pedal.
New rotors are cheap peace of mind.
"It's not easy being Green"
Kermit the Frog
mikey is offline
post #8 of 25 (permalink) Old 08-07-2008, 12:34 PM
kokopelli's Avatar
Quoted: 4 Post(s)
Re: Changing rotors
I agree... at least you know what you get that way.. Ron
post #9 of 25 (permalink) Old 08-07-2008, 12:42 PM
jeshua's Avatar
Quoted: 3 Post(s)
Re: Changing rotors
If they can be turned I have them turned, if not then I buy new ones.
Mike Ambs
www.corva.org
- Thomas Paine
Aequitas - Veritas
jeshua is offline
post #10 of 25 (permalink) Old 08-07-2008, 12:42 PM
mikey's Avatar
Quoted: 902 Post(s)
Re: Changing rotors
kokopelli previously said: View Post
That and most places do not put a high priority on re-work, it is usually a "
We'll get to it when we can or feel like it" job.
Kermit the Frog
mikey is offline
Human Verification
