Go Back   Toyota FJ Cruiser Forum > Toyota FJ Cruiser Discussion > Maintenance Tech
Old 12-07-2008, 10:43 PM   #1
FreshChip119's Avatar
Member Number: 16494
Send a message via AIM to FreshChip119
Exclamation Front Diff Leaking
Took off my factory skids today to replace with Demmello one and found that my Front Diff is leaking!
Anybody else have this problem?
What did you end up doing?
I'll be calling Toyota tomorrow to see if they will take care of it under warranty which they should sense it is an internal problem which has not been affected by modifications.
07 Toyota FJC
Voodoo Blue
4x4
"Modified"
Cheap Stuff For Sale For Your FJC Just A Click Away
FreshChip119 is offline
Old 12-07-2008, 10:48 PM   #2
SKINUM's Avatar
Member Number: 18535
Send a message via MSN to SKINUM
Re: Front Diff Leaking
There is a thread on this.
Do u have a pool of fluid or can u see fluid on the skid? If u just see a wet area around your seal and u have no puddles your good. Cuz if you wheel/ have a lift your gonna get some seepage.
$22,500
THE BUILD OF SKINUM CLICK HERE TO VIEW
SKINUM is offline
Old 12-07-2008, 10:56 PM   #3
The skid under it was wet, and a good amount of the diff was wet as well, no puddle or anything i think it may have dried up?
i searched but couldn't find any threads
07 Toyota FJC
Voodoo Blue
4x4
"Modified"
Old 12-07-2008, 11:09 PM   #4
SKINUM's Avatar
FreshChip119 previously said: View Post
If your skid was wet then definitely get that checked out. Below is one of the threads:
Front Diff Seals leaking again
$22,500
SKINUM is offline
Old 12-07-2008, 11:23 PM   #5
Banned
Member Number: 10257
The lemon did that...Toyota put a new diff in.....We thought it was an axle seal until they started taking it apart....it leaked at the top of the diff on mine.....but the fluid ran down the diff onto the axles leaving a puddle under the axle end of the diff....
homedad is offline
Old 12-08-2008, 12:08 AM   #6
tisilverFJ's Avatar
Member Number: 1394
Just had mine replaced under warranty at 45,000 miles. They said the bolts were just loose. My mechanic told me they are only suppose to reseal them now and not replace.
TLCA#16292
Toytec- coilovers with custom rear coils,SS brake lines,front swaybar collars. PM me for TOYTEC Discountshttp://www.toyteclifts.com/index.php...id=84&Itemid=2
All Phase Offroad diff skid,engine skid,Hi-Lift mount,axe/shovel mount,HD LCA frame mounts.
Spidertrax spacers.
All-Pro HD LCA's,Bandi mount.
FabFours front bumper
tisilverFJ is offline
Old 12-08-2008, 12:12 AM   #7
MoabRat's Avatar
Member Number: 1018
Send a message via MSN to MoabRat
Mine was replaced under the drive-train warranty at 43,000 miles. My dealer is pretty great though. I have a lot of mods and it's obvious I use them. They found the leaks while replacing my inner pinion. The front diff is a bit of a known weak point. I think you should be getting it fixed gratis.
Pics of Our Adventures
BRC Moab Partner
TLCA# 16012
U4WDA
MoabRat is offline
Old 12-08-2008, 05:06 PM   #8
yah dropped it off at toyota today so hopefully they willt ake care of it
07 Toyota FJC
Voodoo Blue
4x4
"Modified"
Old 12-08-2008, 06:51 PM   #9
got a call from them they said they found more then just the front diff leaking ill be getting more info later tonight when i go there to get the rental car sense they have to keep it until wed. now
07 Toyota FJC
Voodoo Blue
4x4
"Modified"
Old 12-08-2008, 07:56 PM   #10
just came back pretty cool stuff they let me see the fj in the operation room shes bleeding and toren apart
hopefully she will be better hahaha
toyota of orange says this is uncommon but explained to them that many people have had this problem
07 Toyota FJC
Voodoo Blue
4x4
"Modified"
