Maintenance TechThis forum is for discussion of all aspects of maintenance that should be performed on the FJ Cruiser to keep it operating at maximum efficiency.
I have read on here that the drive shafts for the fj should be lubed every 5000 miles. I have never lubed the driveshaft of any vehicle so I am a little confused. Where should I lube the driveshaft, what part of it, how much lube or oil should be put on it, and what kind of lube should I put on it and where can I find it? Thanks for the advice.
Re: Drive shaft lube
You'll find two slip joints and a zerk fitting on each. I believe a moly based grease is preferred for slip joints. Each U-joint will also have a Zerk fitting. Not too much in the slip joints; two or three squirts. Some say to lube the U-joints until you fluse the onld grease and some say it's not nessessary. I use one of the small grease guns (3oz) and just about used the cartridge up. At 15,000 miles everything seemed pretty dry. Cheers.. Ron
08 SS, Kokopelli decals, SS valve stem caps, 35PSI COLD and exhaust tip
i do it every oil change with the amount Ron listed above. I give the ujoints enough til the grease starts to come out and make that crackling noise, I then wipe the excess off.
__________________ 2007 Voodoo Blue 4x4 TRD supercharger
TRD CAI
TRD exhuast
ARB bumper
OME lift (886s and 895s)
Warn M8000
IPF 900XSD lights
BFG AT's 285/70/r17 on stock steelies or
34x10.50r16 Super Swamper LTB's on offroad package wheels
Bajarack
Safari Snorkel
Dirty Parts dual battery kit with Optima
Demello Hybrid Sliders -Layton
When I drop my skid this week gotta remember the two near the drivers side DOH..missed it last week while wrenching
Do you have any trouble getting the grease gun off of the front ujoints/driveshaft???
I always have to get a flathead screwdriver to pry the grease gun off. It is a PITA. I make sure the nip is clean and that i am pulling straight off and still, hard as anything to get it off.
TRD CAI
TRD exhuast
ARB bumper
Warn M8000
IPF 900XSD lights
Bajarack
Safari Snorkel
Can't you loosen the "nozzle" on your grease gun? I have an ancient gun that you can loosen and tighten the aperature. Sorry for the choice of words but I just don't know the technical terms. The part that fits over the zerk fitting rotates on my grease gun. Righty tighty, lefty.....you know
__________________ '07 FJ, C package, 5A, Ti
mods so far
Mod, mod, and more mods and it still looks way to friggin' stock.....grrrrr
So do I have to use a grease gun to lube the drive shaft? Or can I just grab the grease with my fingers and spread it on the drive shaft? I'm asking because I don't have a grease gun. And is the mobil 1 synthetic grease they sell at autozone ok to use on the drive shaft? Heres the url AutoZone.com | Lubricant/Grease
Thanks again for the answers because this is totally new to me and I don't want to mess up my new truck by putting something on it that does not belong on it.
Grease gun.. The slip joints have a zerk fitting. That's what they mean by "lubing the drive shaft". It's not actually the shafy, but rather the slip joints.. Cheers.. Ron
Yep, you need a grease gun because you are not greasing the outside of the shaft or U-Joints. Push the end of the grease gun on the zerk fitting and pump away into the u-joints till you push the old crap out. As Ron said...only about two or three pumps on the slip joint.
Layton, try angleing the tip of the grease gun at a 45* to remove from the zerk. I have to literally push the tip of my gun into the zerk or grease just pushes out around the fitting rather than going into the zerk. I use M1 synthetic pink grease....keeps me in touch with my feminine side...lol.
“Since you have chosen to elect a man with a timber toe to succeed me, you may all go to hell and I will go to Texas.”
