Go Back   Toyota FJ Cruiser Forum > Toyota FJ Cruiser Discussion > Maintenance Tech
Old 08-07-2009, 08:35 AM   #1 (permalink)
stingen's Avatar
Member Number: 3414
Amsoil Severe Gear 75W-90 (API GL-5) for 6 speed MT
Not trying to beat a dead horse again and I'm sure the answer exists somewhere in the black hole of past posts but I just purchased all my oil for the front- rear diff, trans axle, and 6 speed MT.
My question is can I use the Amsoil Severe Gear 75W-90 (API GL-5) in my 6 speed MT? I've read that others were using GL-4 and/or another version of the Amsoil 75W-90.
Jason
stingen is offline
Old 08-07-2009, 08:42 AM   #2 (permalink)
VT_RainMan's Avatar
Member Number: 10271
Re: Amsoil Severe Gear 75W-90 (API GL-5) for 6 speed MT
stick with what other's are using.... that would be my suggestion.
2007 FJ 6MT black -n- black
VT_RainMan is offline
Old 08-07-2009, 09:11 AM   #3 (permalink)
Member Number: 1654
Use the GL-4 since it is recommended and available in 75-90. I just had to go look in the garage to see which I had used and it was 75-90 GL-4 Manual Transaxle/Transmission Lube
Bart & Julie-Life Saving Firefighting Off-Roading Fools
"Me thinks the world is crazy save thee and me, and at times I wonder about thee." Samuel Johnson, 18th century English writer
"There is a knowledge curve in EMS. You start out at knowing nothing, go to knowing something, progress to knowing a lot, maybe come close to thinking you know everything, and then slowly start to slide down as you realize more and more you know less and less of what you thought you knew. And that is probably the place you want to end up. -Street Watch
'08 Trail Team 6spd w/Icon - SOLD
'97 Land Cruiser w/e-lockers
shfd739 is offline
Old 08-07-2009, 09:17 AM   #4 (permalink)
MIKESCRUISER's Avatar
Member Number: 16266
Amsoil Severe Gear 75W-90 (API GL-5) is ok to use.
check here
AMSOIL Products - Auto and Light Trucks Lookup - amsoiloaf.1573014
Check out my RIG
http://socalfjcruiserforums.com/foru...read.php?t=218
check out new FJ Cruiser shirts
http://www.fjcruiserforums.com/forum...er-shirts.html
MIKESCRUISER is offline
Old 08-07-2009, 09:30 AM   #5 (permalink)
Wilkie's Avatar
Member Number: 15645
I used Amsoil Severe Gear 75W-90 in my front & rear diffs, my transfer case AND my manual transmission. No problems at all and that was 20,000 miles ago.
Wilkie
Wilkie is offline
Old 08-07-2009, 09:37 AM   #6 (permalink)
The thing I like about severe gear is you get to go 100k w/o changing the fluids vs factory 30k intervals.
Check out my RIG
