Go Back   Toyota FJ Cruiser Forum > Toyota FJ Cruiser Discussion > Maintenance Tech
Old 08-21-2009, 09:48 AM   #1 (permalink)
Member Number: 27898
How to reset the oil change "engine Maintenance" light
Sorry this is a basic question and can't find what I need to in search.
I don't have a monual as it did not come with my FJ for general maintenance. My engine maintenance light started flashing at start up for about 10 seconds and now stay on. It is about time for oil change so I figure that is what it is. I am going to change my oil this weekend and need to know how to reset the maintenance light. Can someone walk me through this?
I also need to know what engine oil weight to use and how many quarts is needed.
slickrock is offline
Old 08-21-2009, 10:19 AM   #2 (permalink)
Member Number: 30097
Re: How to reset the oil change "engine Maintenance" light
To clear the light: with the truck off and the keys out of the ignition press and hold the odometer/trip button on the gauges and insert the key and move it to the "on" position. Do not start the engine though. Keep holding the button until the little dots go away (you will know what Im talking about when you see it). That will clear the light
DEMELLO SALES is offline
Old 08-21-2009, 10:23 AM   #3 (permalink)
Member Number: 14683
I'm glad the Canadian market FJ doesn't have that idiot light. You will find the procedure here:
"maintenance Required"
As far as oil, the filler cap states 5W-30. Dealerships may refill with 5W-20. Based on two years of used oil analysis, on a variety of oils, I've had the best results with Mobil 1 European Car Formula 0W-40. This oil is appropriate for all temps from winter to hot summer
However, that particular Mobil 1 is getting hard to find around here. The Canadian chain Canadian Tire carries the made in Germany Castrol Syntec 0W-30. I put in the 0W-30 back in Spring, when I change it out sometime in October I'll send a sample off, and will refill with Syntec 0W-30
I should mention that I noticed not one bit of difference in fuel economy, running either 0W-20 or 0W-40. Running Mobil 1 0W-20, I experienced a lot of nitration and the oil actually thickened up to a xW-30 range.
For bitter cold conditions, eg routine -40 temps, I'd still recommend the 0W-20. But I'd change it at least every 5,000 km
jayman is offline
Old 08-21-2009, 10:31 AM   #4 (permalink)
NDA431FJ's Avatar
Member Number: 10370
Oil change with oil filter change = 5.5 quart
Oil change without oil filter change = 5.2 quart
SURF-N-TURF 2009
TLCA #17592
2007 FJ Cruiser 4x4 Auto TI - Mods too long to list
2007 BMW 335i Black Sapphire - Twin Turbo
2000 Honda Odyssey EX - Navigation
1998 Toyota Sienna XLE - Supercharged (minivan with the element of surprise)
1989 Toyota Pickup - long bed
http://norcalfjs.ning.com/
NDA431FJ is offline
Old 08-21-2009, 10:52 AM   #5 (permalink)
Constantine's Avatar
Member Number: 12716
It looks like your questions were answered, but I have some answers for future questions. This link Toyota FJ Cruiser: Resources & Documentation Archive has pdfs of all
sorts of FJ info including the owners manual and repair manual. No need to
overpay someone on ebay for a used manual when you can get them for free.
Enjoy
Constantine is offline
Old 08-21-2009, 10:53 AM   #6 (permalink)
VT_RainMan's Avatar
Member Number: 10271
These should come in handy...
FJ Cruiser - Owners Manual Online
FJ Cruiser -Service Manual
2007 FJ 6MT black -n- black
VT_RainMan is offline
Old 08-21-2009, 02:16 PM   #7 (permalink)
Thanks Guys!
Old 08-29-2009, 07:18 AM   #8 (permalink)
NJ Georgee's Avatar
Member Number: 15033
Im sorry if his been asked million times but I cant find the imfo.
How do you check the trans oil on the automatic and why is there no dip stick? Is it worry free and just needs to be changed at intervals.
My Avatar is my Ride
NJ Georgee is offline
Old 08-30-2009, 09:25 AM   #9 (permalink)
Oh, you're going to *love* the procedure to check the fluid level!
See attached shop manual section
jayman is offline
Old 11-05-2009, 12:26 AM   #10 (permalink)
Member Number: 25374
jayman previously said: View Post
Wow! Was somebody in Japan smokin some doobage when they came up with that?
Wadda they think it is a manual tranny?
dostrander is offline
