Re: Help! Diff Bolts
On the rear diff, you may find a 6 point 15/16 socket fits tighter.
If the bolts are really stuck on good, always take the fill plug off first. If for any reason the fill plug is seized and you already have drained all the gear oil, you're SOL
Try to enlist a helper, this can even be an older kid or young teen. I've had good luck borrowing the neighbors 12 year old, as he fears me and listens well. Their only job is to tightly hold the socket to the bolt while you try to loosen it. Remember, lefty-loosey and righty-tighty
So, for the rear axle, you're both facing the housing and the front of the vehicle, your legs sticking out from under the rear bumper: the helper would be on the right side of the axle, with a pair of gloves on, firmly holding the socket to the fill plug. You're on the left side, near the left rear tire, putting force downwards on the breaker bar, which will be to the LEFT of the fill plug: lefty-loosey
The rear axle drain plug, you and the helper are in the same position. The breaker bar is still to the LEFT of the drain plug. Except you're [Edit] pushing the breaker bar AWAY from you: lefty-loosey
[I got to thinking about the above paragraph, it was wrong the first try]
The front axle is too tight to enlist/frighten a helper. I should warn you to use a long pair of welding gloves, as its pretty easy to skin yourself if the hex socket pops out, or the plug finally breaks loose
Reason: Made oopsey with loosey
