Maintenance TechThis forum is for discussion of all aspects of maintenance that should be performed on the FJ Cruiser to keep it operating at maximum efficiency.
Thank's ... You say mixed correctly ?? just wondering now if there is anything special to do.
In my jeep i neever had to mix my prestone when it was needed...
You can buy premixed that can be used right out of the container or concentrated (the normal coolant forever) and mix it 50/50 with distilled water. The premixed is way more expensive in the long run.
Re: Simple Question
Tony'sFJ previously said:
I am searching for the brand of coolant that Toyota uses annd recomends.
Toyota Red (undiluted) or Toyota Pink (already diluted w/ distilled water). Only available at dealers. Bring lots of money, they're very proud of both - but is good stuff and I use it in all my Toyota products.
N5MUD
TLCA # 16550
High Desert Cruisers
So does the toyota red still need to be mixed? or just pour straight in.........I dont get this non diluted and diluted stuff
The red is straight antifreeze/coolant. The pink is diluted 50/50. If you buy the straight (non-diluted) you must dilute it yourself. You never run more than a 50/50 mix in the system.
Grok FJ
"Wars begin where you will
but they do not end where you please"
