Go Back   Toyota FJ Cruiser Forum > Toyota FJ Cruiser Discussion > Maintenance Tech
Old 11-04-2009, 02:49 PM   #1 (permalink)
Sh!tyThePirate's Avatar
Member Number: 28054
Best Long Lasting Spark Plugs?
I've been using NGK Coppers for all of my Fjs life (36k) switched 'em out...two, three times? Anyway, I've decided I want something more long term...like 30k-60k lasting ability, with the NGK Coppers I feel like I have to replace them every 7-10k to maintain optimum performance, but boy does the FJ pur when you put them in.
Can anyone recommend long-term spark plugs? Which type? Do you need to put anti-seize on them? I've been putting Anti-Seize on the NGK's but since I take them out so early, I figure it isn't really needed.
Sh!tyThePirate is offline
Old 11-04-2009, 03:50 PM   #2 (permalink)
1911's Avatar
Member Number: 4994
Re: Best Long Lasting Spark Plugs?
Sh!tyThePirate previously said: View Post
Sorry, can't help - I just use regular old Denso plugs, I'm on my 3rd new set.
I always put a dab on every spark plug; ensures that they will come back out no matter what. Especially important when you've got steel spark plug threads in an aluminum head.
N5MUD
TLCA # 16550
High Desert Cruisers
1911 is offline
Old 11-04-2009, 04:00 PM   #3 (permalink)
kualenamanao's Avatar
Member Number: 17859
I would recommend E3 spark plugs. Although there is a lot of speculation about the performance value of these plugs, they have a very long lifespan. I just recently put a set of E3 in my FJ and although I wasnt looking for major performance I was hoping for something reliable. My friends who have been using E3 have put over 50,000 miles on a single set and have had no problems, inspection of the plugs showed no changes from the first time they put them in the car. I hope to get the same longevity.
Would recommend anti-seize as well.
kualenamanao is offline
Old 11-04-2009, 04:08 PM   #4 (permalink)
MrBigAxe's Avatar
Member Number: 12016
I put in E3 plugs about 1,000 miles ago. They are supposed to last a long time, but only time will tell.
EDIT: they are not very expensive compared to other plugs that will fit the FJ. They can easily be found for $5.99 each.
2008 SS, AT, Metaltech Bumper, PIAA 520's, BajaRack, TG Sliders, A Few 6 Circuit Fuse Boxes, SilverStar Ultras, Hi-lift, After-Market Power Inverter, Trail Team Badge, M-PAC Rear Door & Side Rack Combos, #10 CO2 Tank, aFe TBS CAI & Hi Tuck Exhaust, Icon Stage 1 Lift, Camburg UCA, Midland 75-822 w/Bandi & 3' Firefly, Wolo 120 Horns, 285/75/16 Maxxis Bighorns, Badger 5lb Extinguisher, Trasharoo, LED Dome Lights.
MrBigAxe is offline
Old 11-04-2009, 04:27 PM   #5 (permalink)
joenshan's Avatar
Member Number: 18718
What ever toyota put in it from factory. 80,000 miles on my 07 still runs like new. never changed plugs.
I don't drive I travel.
-3" FJ Lift Kit w/spacers and rear ToyTec coils
-Shock skids made by Fjtoyman
-Breather mod's half way finished
joenshan is offline
Old 11-04-2009, 04:50 PM   #6 (permalink)
bartt's Avatar
Member Number: 1660
NGK iridiums have lasted almost 70k in my FJ.
I have a major service coming up and will probably pull them at least to check the gap, perhaps replace them..
These were the most expensive plugs I ever bought, $12 each.
07 Titanium loaded..
Current mods: Custom tube front bumper, scuba breathers, OME883's & Bilstein513's, BFG KM2's, Nitto TG, Trailgear Sliders, K&N, 08 side visors, 35% tint, Redline gear oil, Atrac hack, mini-ITX PC (GPS & wardriving), upgraded speakers, custom rear door sub, custom air dam w/ hella spots and surf rack, grill mounted hella driving and fog lites, air horns, solar batter charger, rear 12V outlet, block heater, painted stock alloys (1 set black, 1 set graphite)..
bartt is offline
Old 11-04-2009, 05:00 PM   #7 (permalink)
Digger422's Avatar
Member Number: 17365
I just swapped out my stock plugs for the Champion Double Platinum. At 35K i had a sudden drop in performance and mileage, so figured that the plugs would be a good starting point.
I am watching them real close to see how performance and my mileage do with them in.
The DangerBuggy: '08 Sandstorm/MT6/OME 3" Lift (heavy) /ROCKTEK Customz Sliders /Ricochet Lower A-Arm Skids & Rock Blocks / Outrider 1/4" Plate FRONT Lower Link Mount Armor/Outrider Extreme Duty Shock Mount Armor/Outrider REAR Lower Link Mount Armor (Pat. Pending)/Outrider Rear 1/4" Thick Diff Armor/Axle Truss /Outrider TBFJ Front Bumper
TLCA MEMBER# 19727
My other ride is a 1991 FJ80 Landcruiser
Digger422 is offline
Old 11-04-2009, 06:44 PM   #8 (permalink)
DEWFPO's Avatar
Member Number: 7505
I have been extremely happy with the factory Denso's and a little anti-seize. After 30K they were only worn .001" off original spec and looked like they could go another 2 rounds before changing.
DEWFPO
Engine Block Heater, '08 Cyclone Pre-Filter, Dual horns, Phillips Osram 70W/65W H4's, RockBlocker and 3M Clear Film, Toyota RearSight Backup Camera.
"Enjoying the Journey"
DEWFPO is offline
Old 11-04-2009, 06:47 PM   #9 (permalink)
I'll check into those E3's and NGK ir..(can never spell the last part). I always find it hard to put on a "little" anti-sieze, but I do guess if you just coat the bottom of the threads, as you screw it in it will coat the rest...
Old 11-04-2009, 06:49 PM   #10 (permalink)
Super Moderator
Fjamming's Avatar
Member Number: 6623
Plugs are pretty easy to change and cheap enough to not let it be a change deterrant. My last set of factory plugs cost~$20. That's cheaper then oil.
Sandoo Blue FJ
Walker Evans 2.5 dia. front shocks, adj. rear reservoir shocks, Pro Links. AP F&R bumpers, AP 1.25" UCA, Demello skid, TMax 9000 Competition winch. Viking Trail Line. 34X10.5X16 Swamper LTB. Trail Gear Sliders, Aeroflow, Lightforce Blitz 240 50W HID, All Pro Swing Out. Bajarack custom low-pro rack. Ricochet LCA armor.
SoCal Events Calendar
Fjamming is offline
