Maintenance TechThis forum is for discussion of all aspects of maintenance that should be performed on the FJ Cruiser to keep it operating at maximum efficiency.
Am I missing something? I've read through the owners manual and the service/maintenance log and don't see anything about changing the diff/t-case gear oils. I only see where it says 'inspect' diff/t-case oil. I switched to Mobil 1 75-90 at 40K. Anybody?
Grok FJ
"Wars begin where you will
but they do not end where you please"
You're right. I did the same double take after reading all the posts here about changing the diff. fluid. From what I remember, the manual says to change it at 30k if you're following the severe use schedule(i.e. towing). The consensus here though seems to be change it AT LEAST every 30k no matter what. Possibly a response to failures in early production models, or maybe just good policy on a 4x4. Certainly can't hurt.
I replaced the rear diff. with Mobil1 at 25k. Haven't done the otheres b/c I've heard they don't need it near as often(don't get used as much as the rear).
2007 VooDoo 4x4 Auto - LOADED
OEM Roof Rack, Rock Rails and Skids
Unknown brush guard and tail light guards
TRD Exhaust
Add'l 12v outlets
Scuba Mod
08-09 side sun visors
Power rear window mod
Backup Camera w/ 7" monitor
