Heads-up on New Run of Skids...
Ok...I recieved these this past Thurs. and installed them this morning...The nuts that are welded to the new cross member are not sized right for M8 bolt with 1.25 pitch....I have no idea what size bolts these nuts fit (I don't stock up on metric bolts)....I had an extra pack of nylock nuts for M8x1.25 bolts left over from another venture....So, I just used these nuts for now to secure the skids to the cross member...Just figure I would give you guys a heads up before you got to installing them then get a small delay...Either you should test fit the bolts into the nuts that are welded to the cross member to see if they fit before you install them, or get a pack of nylock nuts so you won't be slowed in the installation of your skids...I'll let Steve know this week as I'm sure he'll resolve the issue promptly (that is if the problem goes further than my set)....
TLCA#16831
2007 Ti. Silver FJ -Project "Trl Makr"
Stop being a slave to your J.O.B.! Visit Our Website @ www.agel365.com
