Very, very nice looking and I have these on my radar now ; do the joints on the chassis side allow you to reuse the stock size bolt? Also do the axle ends have zerks?
2007 FJ Cruiser:
RockTek Front Bumper
RockTek Tail Lights
Camburg Full Susp. System
BudBuilt skids
Rocky Road Sliders
255/75/17 BFG M/T
They do re-use the stock bolts yes. We do not include zerks, greasing the bolt is much better than greasing the sleeve, using poly bushing lube during the install will work out much better for you.
whats the warranty on the arm's n' bushings????? Lifetime????? Can you lube them up.Thanks
ARB Bumper*OME Heavies*3" Skyjacker rear*Stock Steelies*Nittos Terras 295/70/17*Gobi Ladder*Cobra CB*AP Rock Sliders*Black Bezel*Real Wheels Light Bar*K&N Filter*Choped Body Mounts*Parrot Blue Tooth*Eliminated rear Sway Bar.
These control arm's look great, sounds like a good choice for a up grade. What type of service life and or maintenance needs to be done with this type of up-grade? Is this a direct bolt in and drive?
The arms will have a lifetime warranty against workmanship and defects. The bushings and rod ends are wear items and will not be covered under a warranty. We did choose the highest quality bushings so they will last a very long time.
The arms are a direct bolt in and drive but because the uppers are adjustable you will need to make sure they are the correct length before installing them.
You will need to grease everything during the install which is typical, there isnt really a service timeframe of re-greasing them but if they ever squeek or you just feel like getting dirty its the perfect time.
