Go Back   Toyota FJ Cruiser Forum > Supporting Vendors > Man-A-Fre
Man-A-Fre Man-A-Fre
Old 04-16-2008, 04:16 PM   #111
blgale's Avatar
Member Number: 12332
Re: FJ Cruiser Auxiliary Fuel Tank --> INSTALLED
Dropped my truck off at MAF this morning for my tank install. I'll be picking it up in a couple of hours. The really cool switch/fuel guage is on back order so I'll just have an Aux pump switch in one of the lower panel switch blanks for now.
When the switch comes in we'll try putting it in the unused round hole in the center panel to the right of the radio. This is the area for the fancy Toyota alarm feedback display. If the cool Aussie switch doesn't fit there then it will go in the silver panel to the left of the steering wheel.
My buddy took his FJ in to MAF yesterday but he has a Warn rear bumper that has a mounting bracket in the way. He and MAF are working on adapting the tank mounting to accommodate the Warn bumper brackets. If you have a Warn rear bumper you'll have to wait a little longer for the mounting solution.
BLACK PEARL
TRD SE, OME 3" LIFT, TOYOTA DVD, ARB FRONT BUMPERW/ WARN 8K WINCH, DEMELLO REAR BUMPER, MAN-A-FRE SKID PLATES, OMF BEADLOCKS
blgale is offline
Old 04-16-2008, 04:38 PM   #112
fjctrevor4x4's Avatar
Member Number: 11411
Send a message via AIM to fjctrevor4x4
hmm i need one of these...but live in va....
looks like im going to be the first diyer on this mod
07' non "frescio" Metallic fj
some All Pro stuff
couple new tires
couple new rims
you know the basics
fjctrevor4x4 is offline
Old 04-16-2008, 04:45 PM   #113
Member Number: 17192
I was scheduled for a tank install yesterday and all was well, until 4 hours into the process it was discovered that the support brackets for the Warn rear bumper interfered and the tank wouldn't fit. 2 hours later with truck returned to stock condition (no tank) I sadly left. The fix is simple but requires a small change to the support brackets that shift the tank about 3/8" inch to the passenger side. I was at MAF for the duration of this attempted install and saw firsthand what is involved. Anyone who is comfortable with installing a winch/bumper or lift kit could do this install as long as they respect the fact that while the filler tube is replaced the vehicle's gas tank is open to air and gas vapor is very dangerous. MAF is using the early installs to refine the proceedure and find other issues like mine before they are ready to release the tanks to self installers. They have done installs with stock, Road Armour, All Pro and possibly more rear bumpers without issue. Mine was the first Warn so part of the time was spent in measuring the changes needed for future production. I concur with Larry about the build of the tank and skidplate. mir207's truck was at the shop and I have to say that if he didn't hurt the bigger tank without a skidplate I'm not worried about the production one with a skid. mir207's truck has definetely been driven very hard. The guys at MAF were great and I will be getting a tank as soon as they can make the changes needed which is unknown at this time.
FJ4RWS is offline
Old 04-16-2008, 05:14 PM   #114
Go4aRyd's Avatar
Member Number: 2937
Sorry for your pain - I know what that feels like. We knew Steve would take care you.
Go4aRyd - Voodoo Blue, AT, TRD wheels, BFG A/T KO, WHITE bezel, Demello sliders, Gobi Stealth rack&ladder, PIAA lights, Lowrance Baja 480C, dual battery.
Go4aRyd is offline
Old 04-16-2008, 05:33 PM   #115
CactusJK's Avatar
Member Number: 1157
Does anyone have a picture of this cool Aussie switch/gauge?
blgale previously said: View Post
CactusJK is offline
Old 04-16-2008, 06:50 PM   #116
nevadaesh's Avatar
Member Number: 14345
Uphill and everyone else, you know that I have a stock FJ. But even on our short runs into the desert, we always pack and use extra fuel. So this mod is worth an extreme feasibility look at $ wise. But as everyone knows, 1 mod leads to others that have to be made to compensate for the 1 mod. You probably already know where this is going.
If I have the tank installed, in your humble estimation, what would be the minimum suspension mod that I would be looking at to compensate for the extra weight? Heavy duty shocks and springs? (If "shocks and springs" is all wrong, caulk it up to a real newbie techwise) Then would I have to do something to the front end to compensate for what I did at the back? Feed back would be appreciated by everyone.
KF7FHU
'07 Sun Fusion, MAF aux fuel tank & skids, custom laptop mount, OME mediums, Lucrum mount w Warn XD9000i winch, Waeco fridge, custom storage solutions, Cobra 75 CB, Garmin 76csx GPS, custom aux roof rack, TG sliders, Mombasa awning....
nevadaesh is offline
Old 04-16-2008, 07:02 PM   #117
Pacific Coast Moderator
uphill's Avatar
Member Number: 10461
nevadaesh previously said: View Post
The weight added wouldn't be more than a metal bumper and the fuel you already carry. I think you could run it stock, but it might be worth adding a heavier coil spring. They are NOT expensive.
One day if you want to improve the suspension, you can do that. When we're in Death Valley in a couple of weeks, drive my rig around a bit and see how it "feels" with the improved suspension, tank, etc.
uphill is online now
Old 04-16-2008, 07:55 PM   #118
Swingshiftworker's Avatar
Member Number: 11371
My suspension is completely stock and I have no plans to lift or otherwise modify it because of height concerns.
I've got a Lucrum mount, Warn M8000 winch and extra Optima battery upfront (about 160lbs) and noticed no significant drop in height after I installed them up there, so I wouldn't expect any significant difference in back either. If there is any problem in the rear, I just plan to add a pair of AirLift airbags to carry the load.
BTW: One of the reasons I bailed out on the DV run late last year was concern over the availability of gas and the ability to get to the Racetrack from Furnace Creek or Stovepipe Wells and back to a gas station before running out of fuel. Guess I won't have to worry about that anymore after I get the aux tank installed next week.
Marty
2007 Titanium Metallic Toyota FJ Cruiser
2002 Island Blue Ford F250 4x4 7.3L TD SC LB Lariat
My Build Diary
Swingshiftworker is offline
Old 04-16-2008, 08:17 PM   #119
CactusJK previously said: View Post
The link below shows an 80 series aux tank on top and below that is a picture of the type of guage/switch that steve is trying to get from AU. The guage part has to be built to match the sending unit already in the tanks.
Man-A-Fre LONG RANGE 24 GALLON 80 SERIES AUXILLARY FUEL TANK
FJ4RWS is offline
Old 04-16-2008, 08:44 PM   #120
CactusJK's Avatar
Member Number: 1157
I noticed that a lot of new forum members are getting tanks. Other than Uphill and Mir I have not seen any of the other forum heavies weigh in yet. Looking for feedback from the masters!
CactusJK is offline
