You fill it through the same filler tube as with the OEM tank.
It looks like it hangs a bit lower than your exhaust (IMO). I might be wrong, but that's how it looks from these pix. Please verify.
I was down on the ground when I took the photo and yes, maybe an inch lower than the exhaust, but nothing appreciable.
Also, I'm wondering how the extra weight when full affects your handling.
It handles better with the tank on since I had been driving with OME heavy springs for about a month in anticipation of this mod and the back was a bit "bouncy" on top of the hard springs.
The tank weighs about (don't hold me to the weight - this is an approx. only) 40 lbs. Gasoline weighs about 6 pounds per gallon, which means that IF THE TANK IS FULL, it's an additional 114 pounds, or roughly 150 pounds more than empty/no tank. When you are carrying 10-15 gallons in Jerry cans on the roof of your rig for trips since the FJ has short legs and you need the spare fuel, you are packing roughly the same weight. The only difference is that my center of gravity is substantially lower and I don't have to horse the cans up and down from the roof rack anymore.
Around town with an empty auxiliary tank 40 lbs. means literally nothing to the handling of the FJ.
I know I don't get out all that often and when I do, I'm a sissy.
Where is Larry? What have you done with him!???
M
"That seems to be when you're in your element and at your happiest. ...just an observation, but put a winch line in your hand in a boreal forest, a muddy woodland, or an arid desert and the word harmony suddenly makes sense "
That is a system like the Landcruiser? with a swich you can use the tank you whant?
OME medium, TRD CAI, Lucrum Mount winch, T-max 10,000 winch, 305/70/16 BFG M/t, Demello Skid Plate, Camburg UCA, Lightforce 240 (55W HID), All Pro (Sway Bar Links, Sway Bar Collars, Upper Links, Lower Links, Transfer Case Skid Plate, Lower Link Skid, Lower Shock Mount Skid), Man-A-Fre Long Travel HD Rear Panhard Rod, SS Braided Brake Line Kit, ARB Air Compressor.
Great stuff Uphill.
But now you won't have that cool "im going on an expedition" look with the tanks on the roof. And i mean, who isn't going for that look?
I love the "your tail pipe is in great condition, you must not wheel much" comment
-Benjamin Franklin"
2007 Supercharged Voodoo Blue
No. The auxiliary tank feeds into the main tank so it's not an either/or dual tank system. The old Landcruisers had fuel pumps and carburetors. It's a more difficult proposition with the FJ's fuel injection system and this turned out to be the more practical and workable solution according to MAF. I agree.
To tell you how sick I am, I was just out driving around so I could transfer fuel from the aux tank to the main tank. The pump is a beast and moves the fuel very quickly, on the fly, while you're driving.
layonnn previously said:
Great stuff Uphill.
Now there will be Pelican cases on the roof where the fuel once was. It'll still have the "look".
I am also looking at having Larry at Dirty Parts install some underbody lighting and need a few photos to the left/right of the tank to see if there is any room left for these lights. Getting my tank installed 1 May!
Jeezo, Cactus- you are demanding.
There is about 6" behind the tank, more than that - maybe 9 inches on the right side of the tank, and a little less on the left. Plenty of room to mount lights (but why??).
Keep in mind that I have no mud flaps and the FabFours rear bumper so your set up could be slightly different depending on your after-market options.
IMO, lights that low will get beat up bad by rocks/mud. I suggest that you install high floods. I'm not saying "copy me" but this solution (below) works.
