Go Back   Toyota FJ Cruiser Forum > Supporting Vendors > Man-A-Fre
Man-A-Fre Man-A-Fre
Old 04-10-2008, 10:31 PM   #41
JPness's Avatar
Member Number: 11697
Re: FJ Cruiser Auxiliary Fuel Tank --> INSTALLED
Hey, Larry! Looks awesome. Do you know if it would interfere with the tow package...looks to be right around the same spot.
Was at Dave's (Croz's...with the sweet 4Runner) the other day...he was doing a body mount chop for me and showing me the pics of you guys out on the trail. Said it was great meeting you.
JP
Basic: Titanium Silver, conv package, upgrade 1, all-weather mats, & towing package.
Mods: OME Medium setup, 16" Konig Countersteer Offroads, 285/75/16 Nitto Terra Grapplers, DO Hybrid Sliders, Gobi Stealth, FJOEL Battery Clamp, TT Badge, blacked out front bezel, much stickers.
"My belt holds my pants up but my belt loops hold my belt up. Who’s the real star of the show? What’s going on down there?"
JPness is offline
Old 04-10-2008, 10:35 PM   #42
thugasaur's Avatar
Member Number: 691
Send a message via AIM to thugasaur Send a message via Yahoo to thugasaur
uphill previously said: View Post
sell blood
Note: For those of you who don't know THUGASAUR personally, he has about 3 times as much blood as I do.
ha ha ha look at you mr funny man i guess you now get more jokes per gallon
1.Chefj's Little known facts: Thugasaur tracked down, strangled, and gutted the Snuggle fabric softener bear because he once had a towel that was...well...not so soft.
2.STOP DRINKING THAT YELLOW KOOL AIDE IT MESSES YOU UP INSIDE!
"Church" V2.0
2007 Voodoo 5AT 4x4
______________________
AFE cai , piaa extreme super whites , demello front skid plate and rock rails and aero flow lens covers , all-pro front sway bar links
thugasaur is offline
Old 04-10-2008, 10:40 PM   #43
crozhawk's Avatar
Member Number: 10443
Send a message via AIM to crozhawk
I guess it's all right .....I didn't see any carpet in the rear though!!??!
....very nice!!
06 4Runner Limited V8 4WD NAV, King front(700lb coils)/King rear w/ custom rear coils,Icon upper A-arms, Shrockworks bumper w/Ramsey winch,In-cab Winch SW/Dual batteries, 2xLightforce 240's, 6xBaja Fuegos, Stubbs' sliders, 17" Procomps w/ 34" MTR's ,SCUBA air system, "Crozbuilt" rear bumper, Allpro rear diff guard, HDPE skids....
crozhawk is offline
Old 04-10-2008, 11:21 PM   #44
Pacific Coast Moderator
uphill's Avatar
Member Number: 10461
JPness previously said: View Post
Dave is a great guy! We just need to relocate him out here so he can continue to play on the Pacific side of the island.
No interference with the tow. There is at least 6 inches between the tank and the rear frame.
uphill is offline
Old 04-10-2008, 11:39 PM   #45
Money Pit's Avatar
Member Number: 18399
For me this makes a lot of sense. I am not fond of gas roped down on my roof if I can avoid it (from a weight too high perspective). This will likely be in my future as well. Really looks good and for my way of thinking puts the weight where it belongs!
FJ-2007:Titanium Silver-4X4-A/T-Rear Diff Lok
Install History: TRD exhaust/K & N air filter/Warn rear bumper/ARB bull bar/Warn 9.5 XP/A-Trac/Sylvania Silver Star Ultra/Aeroflow HLC/Putco LED dome/17X9 MT/Cooper STT 285 70R17/DO Hybrid sliders/ICON Stage 3 Suspension/Total Chaos A-arm Skids/MAF 4+Plus Skids/Scan Gauge II/AVIC-F700BT/Audiovox ACA200W Rear Camera/Infinity REF3022CF
Miscellaneous: KI6WZI/Hi-Lift/Warn & ARB recovery gear/Powertank #10 system/Staun 6-30 deflators/Halon & Dry chem/Tire repair kit
Money Pit is offline
Old 04-11-2008, 01:18 AM   #46
keithh's Avatar
Member Number: 10171
I had mine installed by MAF on Tue 04-08 and all is well. I'm doing some small tests for Steve like actual "fill" size of the Aux tank and transfer times alone with Fuel Gauge accuracy, but it takes alittle bit of time to do these tests. (38 gallons takes a while to use up.) I put my 2" autometer gauges in just under the left air duct. I have also put in a switch to the right of the fuel gauge to control it. I also have a TRD Exhaust and the towing package and everything fits fine. Updates later as I do them. Thanks again Steve.
It's a very well built tank.
keithh is offline
Old 04-11-2008, 02:34 AM   #47
Swingshiftworker's Avatar
Member Number: 11371
I put OME heavies on the back a month or so ago in anticipation of this modification. So it rides just the same as it did before - actually a little softer now because I was banging on those heavies before I added the tank and fuel - so no worries there.
I had success with an AirLift system in my Dodge Durango, which allows you to use air to adjust the resistance according to the load, and will probably install one in my FJ if the weight of the auxillary tank and other gear overloads the stock rear coils, so that I can bleed air off and add more air as the amount of gas and weight of the load varies.
The other option is to install a set of adjustable Rancho RS9000XL shocks with remote control, but that would be more expensive and involved than just adding a pair of Airlift airbags in the rear.
Marty
2007 Titanium Metallic Toyota FJ Cruiser
2002 Island Blue Ford F250 4x4 7.3L TD SC LB Lariat
My Build Diary
Swingshiftworker is offline
Old 04-11-2008, 02:40 AM   #48
StHarris's Avatar
Member Number: 4633
Send a message via AIM to StHarris Send a message via Yahoo to StHarris
pokerDawg previously said: View Post
Making repairs underneath at night. Spotting a crawl at night. Coolness factor
I was following CruiserLarry on a run once and he had them on. He explained the benefits. OK....no more hijack.
Great AUX tank!
Yup, I saw them on a Scout at the FJ45 Run (last weekend in Aug) last couple of years. Really useful when driving at night.
07 Sun Fusion
TLCA # 16633
StHarris is offline
Old 04-11-2008, 02:45 AM   #49
FJ4J's Avatar
Member Number: 9293
best mod yet....wonder if someone will step up and mass produce them to drive the cost down
I would certainly purchase one if it fell in the $500-$600 range.
Stay Classy San Diego....
FJ4J is offline
Old 04-11-2008, 02:53 AM   #50
cruiserlarry's Avatar
Member Number: 2011
No. The auxiliary tank feeds into the main tank so it's not an either/or dual tank system. The old Landcruisers had fuel pumps and carburetors. It's a more difficult proposition with the FJ's fuel injection system and this turned out to be the more practical and workable solution according to MAF. I agree.
Just for the record, its more than a difficult proposition from a technical standpoint - in California (and states that have adopted CA emission standards) it might be illegal. You cannot directly increase the fuel capacity of a vehicle, as it can overload the emissions canisters and devices, allowing more hydrocarbons to escape into the atmosphere. To add additional direct fuel capacity requires EPA certification, a very time consuming and expensive procedure - not worth the expense given the limited marketability of the aux tank for the FJC (Each model year / body style / engine type would require it's own certification in most cases).
So designing a tank that does not directly fuel the vehicle allows the mfgr to bypass emissions certification for the vehicle application, just as if you had a gerry can to pump into your tank...
W6LPB / WPOK492
TLCA #9632
cruiserlarry is offline
