Old 05-12-2008, 10:13 PM   #171 (permalink)
chewey46's Avatar
Member Number: 292
Re: KD7NAC_07FJ a.k.a. Clark's Mods
DUDE!!!!!! You did this with your peg leg?!?!?!?!?!?!?!?!? Dude, why didn't you call me!!!!!
And where is your handicapped parking permit????
[YOUTUBE]
http://www.youtube.com/watch?v=ZPzUx...eature=related
A cross between quasimoto and the elephant man..... But only the good parts!!!!!
Hello chewey46 it appears that you have not posted on our forums in several weeks, why not take a few moments to ask a question, help provide a solution or just engage in a conversation with another member in any one of our forums?
chewey46 is offline
Old 05-12-2008, 10:18 PM   #172 (permalink)
Ben Barnett's Avatar
Member Number: 2738
Send a message via MSN to Ben Barnett Send a message via Yahoo to Ben Barnett
What is an ATRAC Hack?
KD7NAC_07FJ previously said: View Post
I originally posted this over on YotaTech but enough people were asking about my mods at the Tahuya run yesterday I decided to re-post it here.
First "Clark" is the name of my Avatar, the sinisterly smiling frogman. I've had that Avatar since I stared gaming on line a very long time ago and "Clark" is John Clark from the Tom Clancy novels I was reading at the time.
So, This is Clark;
Mods I've done so far;
BFG TA 285/70R17 (33's) KO
Atrac hack - works great.
Rear Dif breather relocate.
Bandi mount.
Dual battery - using painless solenoid and battery tray but custom switch and wiring.
Light bar add-on to stock roof rack (x4 PIAA 510's)
A pair of PIAA 1500 for the back mounted on the rack
Custom Switch Box for Aux Light Switches and Winch rocker switch
3" OME lift
-Front 885 coilovers, N140S struts
-Rear 895 coils, N141 shocks
Road Armor Front Bumper
WARN Rear Bumper
Replace factory sliders with All-Pro sliders
Factory front skid plate powder coated black
A pair of PIAA 520 fogs in the bumper
Warn 9.5xp
In Cab winch controls
Console 12v socket add-in
12v plugs with 115v socket in back.
Ellis Precision Grab Handles.
Black-out - My goal is to eliminate all silver, inside and out
Done:
Painted front Bezel
Painted Interior Dash trim
Steering wheel
Replaced Exterior Door handles with black Tacoma Door handels
Radios
-FT-857D & FT8900 under passenger seat
Springtail M-PAC rack(s)
Kenwood DNX7100 /w Bluetooth & HD
Black out To Do:
Mirrors
Inside Door Handles
Rims
In Work
Radios
-Cobra CB install on headliner /w remote Mic
AUX jack amplifier in-dash installation
Ben Barnett is offline
Old 05-13-2008, 12:39 AM   #173 (permalink)
KD7NAC_07FJ's Avatar
Member Number: 8126
I think this is the thread if not one of the first that explains it: Rear Locker + ATRAC
Another good post on ATRAC hack: 2 cheap and easy A-TRAC hacks
(very) Late 2007 & 2008 and on models have the capability incorporated from the factory - no modification necessary.
there is a good description about ATRAC over on Toyota120.com Understanding & Using ATRAC II+ - Toyota 120 Platforms Forum
Wayne
KD7NAC
Snohomish County SAR
KD7NAC_07FJ is offline
Old 06-09-2008, 05:57 PM   #174 (permalink)
w5wi's Avatar
Member Number: 11734
Wayne,
I hope your ankle is healed and your back in the "mod" business! I've read and reread your build up several times over and it's always inspirational!!!
One question. I recall you drilled out your bandi mount 5/8" to accomodate your ham antenna. I presume it was a 2m/440 antenna. Which antenna did you install?
cheers,
dale de w5wi
Happy Trails!
TLCA #17625
LOS TRES AMIGOS IN MEXICO
TITANIUM METALLIC--A/T
ARB Bumper - Warn Winch - OME Heavy 886/895 - Bandi Mount - All-Pro Lower link skids - Bud Built skids - Snorkle - Toyota prefilter (cyclone air filter) - Optima Yellow Top Battery - Painless Dual Battery Control System - Scuba Driver Mod - Kenwood DNX 7120 GPS - A-TRAC mod - 110v add-on - Rock Rails - Rear Locker - Roof Rack - BFG TA/KO's - ARB Fridge/Freezer - '08 side visor mod - Royal Purple fluids - E3.68 Spark Plugs - All Pro Rear Bumper - All Pro Lower Links - M-Pac rear and side mounts
To be continued...
w5wi is offline
Old 06-09-2008, 06:13 PM   #175 (permalink)
Member Number: 8126
Thanks Dale - wait until you see my next project but I'm not telling until after it has been bench tested.
The Bandi mount has a Diamond SO-239 mount with RG58 coax kit and I have 3 different Diamond antennas a 2m, a 140/440 and the only quad band antenna specifically made for the FT8900R the Diamond CR-8900A.
I've had pretty good luck with the Diamond/Yaesu combinations though I do have a number of others I use with the FT-857D on the other bumper SO-239 mount.
the ankle is good, the hardware was removed last Thursday and now I feel like I can really start walking again. The physical terrorist is having her way with me three nights a week and I'm working it the rest of the time. I'll be back in the water before you know it
Wayne
KD7NAC
Old 08-05-2008, 04:04 PM   #176 (permalink)
Member Number: 8126
Body Mount Chop
Many have done or wanted to do the body mount chop to get that extra clearance for bigger tires. I don't really have a tire clearance issue but I can't run chains with the 285/70R17s on.
ACR&O offered up a great deal at a "reasonable" local shop. They are in Auburn and I'm in Everett, wasn't too bad a drive.
So Clark goes under the knife;
The All-Pro plate
Clearance before at full turn (about 1 inch)
After at full turn (about 5 to 6 inches)
And one more thing to check off the list
Wayne
KD7NAC
Old 08-05-2008, 06:45 PM   #177 (permalink)
Member Number: 19892
Re: Body Mount Chop
Those ACR&O guys do great work from looking at the different posts on here where they are involved.
This is one of the cleanest and most professional looking chops I've seen and with the AP Plate the strength is retained.
Very nice indeed.
Eric
KJ4ETF
TLCA 18721
07 FJC, Black Diamond, 6MT
Looks like this FJ is going to be a Money Pit!
Mountainclimber is offline
Old 08-05-2008, 07:21 PM   #178 (permalink)
radiorobwalker's Avatar
Member Number: 13412
Send a message via AIM to radiorobwalker
+1 on ACR&O. John knows his stuff.
...and Wayne, good to see you're back on your feet!
Rob Walker
2008 Sandstorm
Seattle, Washington
radiorobwalker is offline
Old 08-05-2008, 10:37 PM   #179 (permalink)
radiorobwalker previously said: View Post
X2
Eric
KJ4ETF
TLCA 18721
Old 08-13-2008, 11:32 AM   #180 (permalink)
chewey46's Avatar
Member Number: 292
I should have checked this out when I saw you on Saturday Wayne.....
I guess I was too busy drinkin my Mojito and smokin the 4 racks of ribs..... and smoke salmon..... And the burgers..... and hot dogs..... I think we had enough food!!!!!
[YOUTUBE]
chewey46 is offline
