Old 06-18-2007, 10:18 AM   #11
Terahex's Avatar
Member Number: 1680
Location: HELL ...................... if I don't change my ways :)
Re: Clark's Mods
GREAT Rig and nice mods.
2007 Toyota FJ Cruiser MT6 VooDoo Blue (FE, CQ, GY, RB, UR, CF, C7, V5)
Mods: Kenwood DNX7100 | Expedition One Sliders | OME Medium Lift | Original Bandi Mount | CB | 285 Nitto TerraGrappler | HiJack Roof Mounts | ScanGageII | Rear Door Storage Net | TireCover Mod | PIAA Headlights | Passenger Armrest | VooDoo Tent Trailer
WishList: Skid Plates | Wet Okole
Member: NorthWest FJ Cruiser Club
Terahex is offline
Old 06-18-2007, 10:26 AM   #12
MoabRat's Avatar
Member Number: 1018
Send a message via MSN to MoabRat
Re: Clark's Mods
Well done installs. Very impressive ride.
Pics of Our Adventures
BRC Moab Partner
TLCA# 16012
U4WDA
MoabRat is offline
Old 06-18-2007, 10:26 AM   #13
KD7NAC_07FJ's Avatar
Member Number: 8126
DRL Switch
Like so many others I want to be able to turn off my DRLs. Eventually I will be moving the DRL circuit to separate lights on the bumper but for now to keep the gate guards happy I added a switch using the OEM "Auxiliary" light switch (fog light switch) from Man-a-fre and built a harness from the four pigtails.
The two Yellow wires are spliced together and are the switched power leads.
The Black is ground for the LED
The White is the power feed lead.
My intention was to have the switch light up when the lights were on but the switch is set up to be lighted when the dash lights are on so the way I have it wired now the light is very dim. There is a power drop off when the DRL circuit energizes and its constant current isn't enough to light the LED fully. I may just end up wiring the switch's LED to the dash lights but I'm still thinking on that one.
Behind the left light assembly is where the DRL Resistor is located.
You can see in this picture the blue/grey and white/grey wires and the plug that plugs into the resister just behind it. If you wanted to disable the DRLs entirely all you would really need to do is disconnect this plug.
I cut the blue wire (no the FJ didn't explode ) and spliced in the new switch harness. The white wire goes to the blue/grey side coming from the FJ. The yellow wire goes to the blue/grey side coming from the resistor plug.
After pulling the wires, soldering/heat shrinking all connections and looming the harness back to the firewall I ended up with this;
The new harness is on top of the wire cutters shown in the picture and the old harness is below them.
And the switch takes up the blank off to the right of the clutch start cancel switch like this;
Now I can switch my DRLs on and off at will
What I still need to find is the little vinyl letters someone had used here. Then I can put "DRL" on the switch.
KD7NAC_07FJ is offline
Old 06-18-2007, 10:31 AM   #14
Member Number: 8126
Camper "Mod"
Maggiolina Airland car top camper.
Stowed;
Deployed;
Mounts on the stock roof rack with Yakima "Low Rider" Towers and Yakima 58" crossbars.
Old 06-18-2007, 10:35 AM   #15
The Laughing Moderator
LandCruiserSteve's Avatar
Member Number: 8627
Re: Dual battery
Wow!! That's the kind of mods I love to see. Well thought-out and precision work. (And, I plan to steal a bunch of your great ideas, if you don't mind . . . )
Great job!!!!!!! Clark is one lucky FJ.
KD7NAC_07FJ previously said: View Post
Now, that's the sign of a true FJ-modder. I love that pic!!!
Steve
The '07 Kiroi Hako
'78 FJ40
TLCA #6727
UFWDA
LandCruiserSteve is offline
Old 06-18-2007, 10:46 AM   #16
Member Number: 8126
Winch Cover plate
The only thing I don't like about the Road Armor bumper is the "toothless" look of the winch hole.
So I'm working on a cover plate. I finally got the 1/8 chunk of diamond plate bent. I couldn't find anyone with a break that could bend sheet that heavy so I took it over to a friends and we put the torch to it and I think it turned out fine.
I welded some 1/8 inch expanded to the back to match the grill and bordered it with some 16 gauge strips that I brazed on.
Fit check
From the front
I've got a lot more clean up to do before powder coat so more on this mod later.
Update: I've put this one on hold for the time being. That hunk of steel got a lot heaver then I wanted it to be so I' m going to re-do it in aluminum. When it gets a bit warmer
Old 06-18-2007, 10:48 AM   #17
Member Number: 8126
Re: KD7NAC_07FJ a.k.a. Clark's Mods
Thanks guys - I didn't realize how many posts got posted before I was done
And feel free to plagiarize and ask as many questions as you like - I sure did to get to this point
The two biggest inspirations for most of my mods are Sbechtold and SwissArmy.
I still plan on doing the Map light mod but thanks to wesayso I now have to figure out how to incorporate my Scanguage into it
Old 06-18-2007, 10:50 AM   #18
chewey46's Avatar
Member Number: 292
This is even nicer in person....
I got the pleasure to see this rig yesterday (6/17/07)!!!!!!
Wayne you are the man, the myth...... The Legend!!!!!
[YOUTUBE]
http://www.youtube.com/watch?v=ZPzUx...eature=related
A cross between quasimoto and the elephant man..... But only the good parts!!!!!
Hello chewey46 it appears that you have not posted on our forums in several weeks, why not take a few moments to ask a question, help provide a solution or just engage in a conversation with another member in any one of our forums?
chewey46 is offline
Old 06-19-2007, 06:40 AM   #19
Member Number: 8126
Thanks Chewey - it was great to meet everyone. We need to do another meet real soon.
Old 06-19-2007, 07:00 AM   #20
Ripsnort's Avatar
Member Number: 8953
Great write up Wayne! I was drooling over your mods, and now I'm drooling over the time you had to do all of this! Great work, the rig looked great last Sunday.
Ripsnort's Stable
Lifetime Memories Productions-Sports Photography
TLCA #17429
“Me fail english? Thats unpossible.”
Ripsnort is offline
