Old 07-26-2007, 12:09 PM   #11 (permalink)
wrigman's Avatar
Member Number: 3274
Send a message via Yahoo to wrigman
Re: Meet the Scorpion (Uphill's Build-Up)
Awsome wheels and tires buddy!
Did you get the other LCA in??
"A common mistake that people make when trying to design something completely foolproof is, to underestimate the ingenuity of complete fools"
SF, A/T, Conv. Pac.,Aeroflow HLC's, Demello sliders, Demello Skid plate, OME 2" lift, BFG A/T, K&N filter, Magnaflow exhaust, KC 100 watt and 130 watt slim lights, Two tone air horn,Demello prerunner bumper, rear tow hitch,Allpro LCA's and Skids, Mile marker PE8000 winch, Amsteel blue winch rope.
Treadlightly member.
wrigman is offline
Old 07-26-2007, 05:12 PM   #12 (permalink)
Pacific Coast Moderator
uphill's Avatar
Member Number: 10461
The Scorpion visits Big Bear Lake 7/26:
"What I see in Nature is a magnificent structure that we can comprehend only very imperfectly, and that must fill a thinking person with a feeling of humility. This is a genuinely religious feeling that has nothing to do with mysticism."
-- Albert Einstein
The Build-Up Continues:
On the way back from Big Bear Lake, I stopped at Demello's and ordered Donohoe upper control arms (that turned out to be in-stock and available at Donohoe Racing. I know that there is some debate as to the relative value of replacing the OE upper control arms.
I'm running very heavy beadlock rims and heavy tires and feel that because I made this choice and intend to run the rig not just off pavement but off road, it was warranted. Donohoe UCA's are constructed of heat-treated aircraft-grade aluminum. They feature Uniball misalignment spacers and adapters. Dust cover to protect the Uniball, Teflon-lined bearings, and allow for Caster & camber adjustments.
I also ordered Light Racing jounce shocks.
The JounceShocks form the backbone of a secondary suspension system that dramatically increases the capacity of the FJ's vehicle suspension. Driving off-road the FJ won't feel as though it's bottoming. It also feels as if it's moving up and down less when the JounceShocks are added.
As Light Racing advertises, "When the suspension compresses it drives the shaft of the JounceShock into the JounceShock body. The shaft compresses the nitrogen volume and since the nitrogen is in a closed cylinder, the nitrogen pressure increases dramatically as it compresses. This gives a smooth exponential increase in force (like an air spring) instead of the force spike that occurs when typical suspension systems bottom out. The valving inside the JounceShock is designed such that after the JounceShock has compressed the suspension falls away faster than the JounceShock can extend. Therefore all of the energy that was put into compressing the JounceShock is dissipated by the valving rather than pushing the suspension back out. This is a key factor in why the JounceShocks are so effective for high energy absorption and vehicle control."
It all comes back to an ounce of prevention being worth a pound of cure. You can still over drive JounceShocks but it provides a back up to your suspension system. The UCA's and JounceShocks will be installed by Demello next week.
"L'audace, L'audace, Toujours l'audace!"
THE SCORPION
véhicule tout terrain scorpion
скорпион сервисное транспортное средство
โตโยต้า จัตุรงค์ ยาง ล้อเลื่อน แมงป่อง
vier Radantrieb vom Straßenfahrzeug Skorpion
automóvil cuatro rueda Escorpión
蠍子, 豐田越野汽車
Нэвтрүүлэгч хилэнцэт хорхой
macchina fuoristrada lo Scorpione
uphill is offline
Old 07-26-2007, 05:38 PM   #13 (permalink)
Raptor-nator
Shadow-Warrior's Avatar
Member Number: 3913
Very cool buddy, I haven't taken the time to learn about the JounceShocks, now I have just learned what I need to know about them. Thanks Very cool, the rig does look great!
"It’s Not An Assault Rifle, It’s a Jihadi Paradise Attainment Facilitator"
TLCA Member : #18084
Honorary AZFJ Club Member
FJ Cruiser Club Member
Meet The RAPTOR 2007 TRD SE
Shadow-Warrior is offline
Old 07-26-2007, 05:50 PM   #14 (permalink)
Raptor-nator
Member Number: 3913
Rep Points to ya Buddy! Great job on the build
Old 07-26-2007, 06:02 PM   #15 (permalink)
RicoVerde's Avatar
Member Number: 11994
Nice Larry.
I have enjoyed seeing this progress over the past month and the tires and rims are definately the topping on the cake.
Those WE rims are perfect on the FJ
Rico's Rhino
'07 BD, AT, AllPro sliders, Hilift , fourtracks shovel mount and shovel, nuvi 660 GPS, ProClips for ipod and GPS, Cobra CB, Bandi mount, 4' firestick, EMU Heavy/Med suspension, Hella Black Magic driving lights on Defiant bar, 5 IPF lights on N-Fab roof bar, 3 pc. Allpro skids, AllPro pro links with skids, AFE CAI & TBS, BFG 285/70/17 M/T, TWM shift knobs, Wet Okole seat covers, AllPro rear bumper, AllPro high clearance exhaust, Lucrum Mount, M8000 w/synth line, gloomy bear
RicoVerde is offline
Old 07-26-2007, 06:03 PM   #16 (permalink)
RicoVerde's Avatar
By the way, how is the ON road ride and noise with the new rubber?
I really like the look, but my FJ is my daily driver.
Rico's Rhino
Old 07-26-2007, 06:57 PM   #17 (permalink)
uphill's Avatar
There is nothing like returning to a place that remains unaltered to learn the way you, yourself have changed.
THE SCORPION
蠍子, 豐田越野汽車
uphill is offline
Old 07-26-2007, 07:01 PM   #18 (permalink)
uphill's Avatar
RicoVerde previously said: View Post
Nice Larry.
I chopped the body mounts before putting the 305's (34 inch tires) on the FJ but I do have some rubbing issues. That's one of the reasons I visited Demello Offroad today. In addition to the new stuff, we're going to do a more aggressive body chop and it's difficult to describe the way it rubs, but it doesn't look like it's going to be much work to eliminate the problem. (famous last words -- I think Napoleon said that about the British on the eve of Waterloo)
THE SCORPION
蠍子, 豐田越野汽車
uphill is offline
Old 07-26-2007, 07:17 PM   #19 (permalink)
Raptor-nator
Member Number: 3913
uphill previously said: View Post
You going to post some before and after pics of the body mount chop?...I'm doing mine next week it would be helpful to know what will be the best way to do it. I will be running 34's or try 35's if I can get them to fit without rubbing with the DR. Thanks again Larry
Old 07-26-2007, 07:42 PM   #20 (permalink)
Not Serious
MissFJ's Avatar
Member Number: 1937
Oye, that's a long list of mods! Wheels look great, as does the rest of the rig!!
Who knew someone from the DA's office could be into having fun
MissFJ is offline
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
