Old 02-21-2008, 09:33 AM   #61 (permalink)
Mr R2FJ's Avatar
Member Number: 14854
Send a message via AIM to Mr R2FJ Send a message via Yahoo to Mr R2FJ
Re: Mr & Miss R2fj Build Thread
That's the shocks. You can get heavier springs.
Yes this I understand, the only reason I mentioned the shocks was because you mentioned "firming up the ride" when you need it with your adjustable WE setup. I'm not sure what that has to do with carrying more weight? I know I can get heavier springs I'm just wondering what might be a good combination with the all-pro fox setup.
For some reason my communication isn't coming through clearly so I'll try again.
I'm planning on the full fox setup from all-pro. 2.0" diameter so I can get compression adjustable front and rear shocks with the 2" lift rear all-pro branded springs. My concern here is that we like to carry a LOT of weight in the rear. 4 full scepter cans, maybe a AUX gas tank if MAF ever produces it, heavy fridge, recovery gear, etc.. It really sags the stock suspension. I'm concern that the rear all-pro springs provided may not be a good spring rate for the weight we like to carry in the rear. I know you can adjust the preload in the front because coilovers allow you to do this, but it's the rear I'm a but concerned about.
Most likely I'll just use whatever they send me and if I need more step it up to a stiffer spring. I was just trying to avoid the trial and error method if someone had a good suggestion. All-pro has not been much help when I call them. Their webpage says "15% stiffer than stock" for the rear spring, but the person I spoke to said it was rated to carry the same weight as stock.
.:*~*:._.:*~*:._.:*~*:._.:*~*:._.:*~*:._.:*~*:.
2007 FJC BUILDUP
Mr R2FJ is offline
Old 02-21-2008, 09:59 AM   #62 (permalink)
tibaal89's Avatar
Member Number: 8825
Send a message via AIM to tibaal89
OME Heavy!!
-Mike (KE7ULD)
Check out my blog thing!
Something there is that doesn't love a wall, that wants it down...
AZFJ.org - Arizona FJ Cruisers!!
tibaal89 is offline
Old 02-21-2008, 10:44 AM   #63 (permalink)
Mr R2FJ's Avatar
I'd love to know the springs rates of the OME heavy VS what all-pro provides as well as the lift over stock on both.
2007 FJC BUILDUP
Mr R2FJ is offline
Old 02-22-2008, 10:00 PM   #64 (permalink)
cruzinwyo's Avatar
Member Number: 7279
Rear Spring rates
Unfortuantely there is no Fox in this, but maybe if you bug Jeshua he'll do some research! Have you looked at MIR207, he has some serious weight and runs the Heavy OME. As far as lift, I wouldn't worry about height/leveling...just look at kurt's rig. I'm sure the OME heavy will be a different type of ride, but with your off road styles it seems the perfect match!
come join us---> AZFJ Calendar
The Black Betty Build
cruzinwyo is offline
Old 02-23-2008, 12:13 AM   #65 (permalink)
Mr R2FJ's Avatar
fox doesn't make a rear spring (it's an allpro) and you have given me EXACTLY what I need.. thank you!
2007 FJC BUILDUP
Mr R2FJ is offline
Old 03-24-2008, 10:42 PM   #66 (permalink)
Miss R2FJ's Avatar
Member Number: 14864
Send a message via AIM to Miss R2FJ
Our latest update:
As you have all seen by the drama of our install, here is our new suspension installed correctly! FOX Racing Shox 2.0" Adjustable Front coil-overs, and Fox rear piggy-back, including Camburg UCA's and replacement with steel break lines.
My latest project was creating some rear storage for us, so I built this shelf and coated it with the Duplicolor Roll-On Bed Liner from Auto Zone.
After our Coleman Powerchill zapped out on its second voyage, we returned it and decided to just put the money down on an Engel 45.
I've made some changes to the M-Pac system as well, will post up new pics when that gets completed. We also have a couple of projects sitting in the garage that we are way to lazy to work on at this moment, but hopefully we will get to them soon!
Camping Lab Rep!!
R2FJ-The Force is strong with this one!
The Adventures of Josh and Heidi
I'm a female, liberal, vegetarian, and I own a gun.....
Miss R2FJ is offline
Old 03-25-2008, 03:09 AM   #67 (permalink)
Pacific Coast Moderator
uphill's Avatar
Member Number: 10461
Re: The Force is Strong With This One: R2FJ (by Mr/Mrs R2FJ)
I've been watching your build-up develop and take shape.
R2FJ? Not Really IMO - transforming into all the comforts and power of an Imperial Star Cruiser.
How does the Dept. of Transportation
convince deer to cross the road where
these signs are displayed?
uphill is offline
Old 03-25-2008, 10:55 AM   #68 (permalink)
Miss R2FJ's Avatar
uphill previously said: View Post
Ha thats true...but then we'd have to be the bad guys!
I guess if it were silver it could be the Millennium Falcon!
Camping Lab Rep!!
Old 03-25-2008, 11:17 AM   #69 (permalink)
Member Number: 16653
Re: The Force is Strong With This One: R2FJ (by Mr/Miss R2FJ)
Sweet. Now someone should name their Sun Fusion C3FJ and start modding.
bullrat is offline
Old 03-25-2008, 11:37 AM   #70 (permalink)
Miss R2FJ's Avatar
bullrat previously said: View Post
This is what I have been saying! We already have Vader here in AZ...we could have a whole crew of Star Wars FJ's!!
OMG I'm such a geek....
Camping Lab Rep!!
