URD Thorley report
The 35's are just killing me in daily driver use, in both gas and performance. I have to downshift to 4th to pass, and on freeway hills. So I am really hoping this last engine tweak will help me out of that.
I had photographed a whole series on installing the Thorleys. But then I just deleted all the pics. Nice. So these 3 are all there are:
Thorley's dyno sheets say to look for an increase of 18HP and 28 ft/lbs at 3500 RPM. And you have to get to 3500 before it really comes in. After only one drive home I can say it is faster, but not as enjoyable because I was in the quiet and respectable South OC suburbs.
With URD's Y-pipe and custom 3" exhaust I am very conscious of making a little too much sound around the neighbors. There is a quiet Magnaflow in there that is helping. Also we did not have crush gaskets and you can hear there is a leak. We'll put new ones in next week when URD gets a delivery. For now it's a touch too loud. Out on the open road I will probably like it a lot.
Installation.. whew. The problem is taking off the factory pipes. There are six 12mm nuts on studs for each side, and they are really bad to get to. In particular, the front-most nut on the left side took us half a day. You will try various combinations of approaching from the top, bottom, and through the wheel well.
Once off, you will have to remove some of the studs to get the Thorleys on. For this you must have a Torx socket. Now I don't mean a screwdriver-type Torx bit - I mean the reverse. Yep, a Torx socket. Can't remember the size now. The studs come out pretty easily and if you break one, it is not as terminal as it sounds, because the nuts will still go on.
