Cobra 75X ST CB w/Bandi Mount & 4' Firefly or 3" Firestick Antennas:
Yaesu FT-8800R Dual Band (2M - 70cm) & Dual Transceiver Mobile Amateur Radio:
Yaesu FT-867D HF/VHF/UHF Transceiver w/ATAS-120A Antenna:
I get tired of stringing coax all the time. I intstalled these bulkhead fitting so I can swap out antennas for my amateurs radios real easy.
Yaesu VX-7R Triband (2M/70cm/6M) Dual Transceiver HT:
Yaesu VX-170 2M HT:
ScanGage II:
Garmin GPSMap 478 w/External Antenna:
Garmin GPSMap 60Cx:
Odyssey 1700 Primary Battery (Primary battery is nly for starting and my ham radios. All my other accessories are wired to my secondary battery.):
Dirty Parts Dual Battery System (I will be upgrading the Optima to an Odyssey 1500 shortly. Need to fab a battery box.):
Spare Fuse Boxes:
(Pics to come.)
DVD Player:
Custom Ipod Mount:
O&B Fab Istrument Cluster Accessory Mount (Radar Detector, Camera, Wig Wags, etc.):
12V Aux Plug Switches (Dash, Center Console, and Cargo Area):
(Pics to come.)
Additonal 12V Aux Plugs:
DASH:
CENTER CONSOLE:
CARGO AREA:
Accessory Switches (GPSMap 498, DVD Player, etc.)
(Pics to come.)
Lighting Switch Gear (Each switch has a built in fuse):
Master Arm Switches (Horn, Compressor, and Winch):
Note: The FJ horn works in normal mode with the master switch off. When I arm the master switch the FJ horn triggers both the air horns and the regular horn.
This is a shot of Center Console:
