Old 07-12-2008, 06:14 PM   #211 (permalink)
FJ #8's Avatar
Member Number: 121
Re: Project SAC'D FJC - Phase II
damn, that really does look sick.
FJ #8 is offline
Old 07-14-2008, 12:09 PM   #212 (permalink)
Moderator
opg4759's Avatar
Member Number: 2775
I have to say I'm very impressed with Don's work.
NUFC
Rig
Black Diamond M/T,Custom XM Inno mount ,Bandi antenna mount/ Yaesu FT-7800r, 4 Piece Budbuilt Skids(still need the gas tank skid), OME 886/895, All-Pro upper and lower links, Procomp 7089, Procomp Extreme M/T's, Project Overkill rails,
Gear
Home Brew
Project Overkill
Always trust the Gene Genie
opg4759 is offline
Old 07-14-2008, 03:57 PM   #213 (permalink)
sbechtold's Avatar
Member Number: 639
opg4759 previously said: View Post
Yeah, but people want to see the masterpieces that you're making.
Member: TLCA / BRC / CA4WDC
sbechtold is offline
Old 07-23-2008, 11:26 AM   #214 (permalink)
doublejfj's Avatar
Member Number: 17287
Thumbs up Re: Project SAC'D FJC - Phase II
I just want to say that I really like your rig. I've only recently begun looking at it (after you posted the swing-out tire carrier) and I must say I previously had missed something good here.
Wow. 5 stars...
J+J+FJ - '08 Titanium MT6 - Not stock, pinstriped paintjob.
Finally, our integrated USB chargers are here!
IP68 cable glands for roof rack wiring!
Tell us why you deserve a FREE Quad USB charger
doublejfj is offline
Old 07-24-2008, 06:33 AM   #215 (permalink)
puulboy's Avatar
Member Number: 8494
Sol
After drooling around your FJ at the summit. I have to say you have got the baddest of the bad in FJ's Nothing even came close to what I saw with yours. Great job. It was also really nice to meet you
thanks
Don
Did someone say RAFFLE ???
AZFJ faithful
Member build page
http://www.fjcruiserforums.com/forum...other-gal.html
puulboy is offline
Old 07-24-2008, 08:11 AM   #216 (permalink)
sbechtold's Avatar
Member Number: 639
puulboy previously said: View Post
Sol
thanks
Don
Thanks Don! It was a pleasure to meet you and everyone else at the Summit.
Old 08-24-2008, 05:45 PM   #217 (permalink)
sbechtold's Avatar
Member Number: 639
Howe Performance HA Steering
Installed my Howe Performance hydraulic assist steering a couple of weeks ago. Spent last week in Tahoe and got a chance to test it out on the Rubicon. One finger steering in the rocks with the locker on is amazing!
The Howe system consist of a high pressure (1450 psi) power steering pump, a rebuilt IFS steering box that Howe goes through and adds internal stops to match your steering throw, a high capacity replacement fluid reservoir with a removable filter, a power steering cooler, a hydraulic steering ram that is matched to your steering box throw and a bunch of aeroquip hose and reusable fittings. Howe definitely builds quality products and they were great to work with on my setup.
I mounted the reservoir in the stock location using a new bracket.
I mounted the cooler to the shock tower.
Howe's high pressure TC pumped bolted right up to the stock mounting location. I used the stock Toyota pulley on the TC pump.
IFS steering pump that I sent to Howe and they ported, valved, rebuilt and added steering stops.
Ram mount. Don at FC built the mount for me out of 1.75" dom tube and bent 1/4" plate on the bottom to add some strength.
Everything installed and working well.
Old 08-25-2008, 04:17 PM   #218 (permalink)
jeshua's Avatar
Member Number: 6888
Thats some very nice steering.
I see you've dragged the pumpkin a little as well.
Mike Ambs
www.corva.org
- Thomas Paine
Aequitas - Veritas
jeshua is online now
Old 08-25-2008, 06:08 PM   #219 (permalink)
sbechtold's Avatar
Member Number: 639
I tried to push some rather large rocks out of my way. Rustoleum flat black is my friend. The steering is amazing. Jeff Howe definitely knows steering.
Old 08-25-2008, 06:35 PM   #220 (permalink)
FJ #8's Avatar
Member Number: 121
you have a work of art there.........BY FAR the best str8 axle fj
FJ #8 is offline
