Old 03-31-2008, 09:22 PM   #1 (permalink)
sbechtold's Avatar
Member Number: 639
Project SAC'D FJC - Phase II
Since my first build up thread has grown and it's hard to find anything I thought I would start a new thread to cover the next phase of modifications.
DIY Beadlock Wheels and 37" MT/R's:
I recently completed a set of weld-on beadlocks and up-sized my tires to 37" MT/R's. The process of installing the beadlocks was pretty straight-forward, but very labor intensive. I'm happy with the way they turned out.
Bare metal rings:
Anti-coning ring welded to outer ring.
Inner ring welded on and rim painted:
Windex is your friend when mounting tires with tires irons
A little ultra black to help make sure nothing leaks:
35 bolts per wheel had to be installed and torque down. What a pain!
Add some air and check for leaks, all is good:
Finished product:
1970 Red Land Cruiser FJ40, 4x4, 3 Spd | Stock
2007 Titanium Silver FJ Cruiser, 4x4, AT | Inchworm Crawler | Demello-Offroad SAC | Diamond Axle | SAC'D FJC - Phase II
Member: TLCA / BRC / CA4WDC
sbechtold is offline
Old 03-31-2008, 09:23 PM   #2 (permalink)
sbechtold's Avatar
Member Number: 639
Re: Project SAC'D FJC - Phase II
Diamond Axle - Full Float "Extra Wide" Rear Axle Upgrade:
After finishing my SAC project I wheeled my FJC for a few months, then jumped right into my next project. I wanted to increase the rear axle width by 3.5" and move up to a larger third that would handle the weight of the FJC. I decided to go with a full float axle running a Land Cruiser 9.5" third. I then called Brian Ellinger at Diamond Axle and placed an order for a new rear axle. Brian was great to work with and makes incredibly strong axles. I then called Jim at Inchworm Gear and order a Land Cruiser 9.5" third member.
Here are the rear axle specs:
  • Diamond Axle housing
  • Toyota Full Float ends
  • 67.75" WMS-to-WMS
  • FJ80 LC 9.5" third member
  • 4.88 gears
  • ARB air locker
  • Solid pinion spacer
  • Quad drilled flange
  • Toyota IFS Hubs
  • Longfield drive flanges
  • Custom length 30 spline chromoly axle shafts
  • FJ Cruiser stock brake setup (ebrake, and service brakes )
I am re-using my FJ Cruiser backing plates, emergency brake setup, calipers and rotors. Brian was able to design and build an adapter that allowed the FJ Cruiser stock brake system to bolt right up to the housing.
Before jumping into the pics here is a quick comparison of the Toyota 8" third to the Land Cruiser 9.5" third.
9.5" on the left, note the size difference:
9.5" on the right. That ring gear is huge compared to the 8".
Before I started to disassemble the rear axle I needed some jack stands. After shopping around I decided to make my own. A little 3x3x3/16th square tube and this is what I came up with. The stands are adjustable in 3" increments.
FJC up on the jack stands. Let the rear axle removal begin.
Axle out and ready to be disassembled. I sent the stock axle housing, axle shafts, backing plates, calipers, rotors and ebrake setup to Brian so that he could use them to make the new adapter that allow me to reuse all the stock braking parts.
Pulling the axle shafts so I can send the axle housing to Brian.
Empty axle housing...
So I ship all the parts off to Diamond and I wait while Brian works his magic.
Old 03-31-2008, 09:24 PM   #3 (permalink)
sbechtold's Avatar
Member Number: 639
Last Friday I arrive home to find a large container in the driveway. It's obvious that the UPS guy struggled with the package and decided he'd just leave it in the middle of the driveway with a few other boxes laying around.
After unwrapping everything this is what arrived. There are more part on the way and according to Brian it will be like Christmas for the next week at my house. I'm sure this will piss of the UPS guy.
I spent Sunday painting and making some new longer shackles.
Since my shackle hangers are frenched into the frame I added a spacer to the shackle by welding a piece of 1/4" plate to the bottom. They are made of the 1/4" steel, so in theory they shouldn't bend, but I may need to brace them.
After replacing all the leaf spring bushings I bolted them back into place with the new shackles. The reason I went to a longer shackle is because the Deaver springs have settled A LOT since they were installed. If this doesn't work I will have to have them rebuilt and add a little lift to the springs.
Today I installed the ARP studs for the third member, then installed the inner oil seals and then installed the third.
I then rolled the axle under the FJC and bolted it in place.
Here the axle is mounted and the u-bolts and shocks installed. I need to charge the shocks with nitrogen tomorrow and mount the reservoirs.
I need to make some tabs for the limit straps and brake lines and weld them onto the axle. As time permits and the rest of the parts arrive I will continue to install parts and update this thread.
Old 03-31-2008, 09:32 PM   #4 (permalink)
Member Number: 3240
Can I have your FJ?
JDEMELLO is offline
Old 03-31-2008, 10:12 PM   #5 (permalink)
Runt's Avatar
Member Number: 10685
I second that......I'll give trade you a hot slightly used 32 year old blonde and two little....wait a minute....forget what I wrote, what was I thinking....ohhh ya damn that Cruiser is amazing. To quote Homer Simpson "uhhhhhhhhaaaaaaaa".......drool ....drool.
3" OME Heavy, OEM Rock Sliders, OEM Ipod Gizmo, OEM Rack, OEM Receiver , 33X12.5X17 Wild Country RVT Mudders on stock alum rims, 255/85/16 Cooper S/T Studded with 5-06 4R TRD Alum. rims, Expedition One Bumper, PIAA Lights on rack and bumper, Dirty Parts Dual Battery Kit, Titan 12,000 lb Winch.
Most Important ! "Scuba MOD"
To come: ARB comp., Snorkel, E1 Rear Bumper & (after Warrenty) RC 6", 4.88 gears, 35"s & TRD Super Charger.
It's a good life...if you don't weaken !
Runt is offline
Old 03-31-2008, 10:17 PM   #6 (permalink)
TCao's Avatar
Member Number: 940
You've been busy Sol. The full float rear axle housing looks great.
2007 Ti FJC
TCao is offline
Old 03-31-2008, 10:30 PM   #7 (permalink)
Fjamming's Avatar
Member Number: 6623
Oh my! Looks great Sol. When will it be up and ready to test?
Sandoo Blue FJ
Walker Evans adj. F&R reservoir shocks. Pro Links. AP F&R bumpers. Demello skid. Mile Marker SE9500C. Viking Trail Line. Super Swamper LTB 34s on Tacoma wheels. Trail Gear Sliders, Aeroflow, Lightforce Blitz 240, Powertank 10lb, Hi-Lift, Jack Mate, Pull-Pal.
SoCal Events Calendar
Fjamming is offline
Old 03-31-2008, 10:36 PM   #8 (permalink)
sbechtold's Avatar
Member Number: 639
It will hopefully be ready in a couple of weeks for a shake-down run. Then it will go into the shop for a cage right before Rubithon.
Old 03-31-2008, 10:44 PM   #9 (permalink)
Fjamming's Avatar
Member Number: 6623
sbechtold previously said: View Post
Are you going with a full cage or partial?
Sandoo Blue FJ
Fjamming is offline
Old 03-31-2008, 10:50 PM   #10 (permalink)
Tim Scully's Avatar
Member Number: 6663
the 37's look great even if missy says they are for girls
Tim
Scully Offroad
tim@scullyoffroad.com
FJTT Driver
Corporate Spokeshole
Missy's SAS Project
Tim Scully is offline
